Smokey Z Posted July 5, 2004 Share Posted July 5, 2004 Has anyone installed a T56 behind and L series Datsun motor? I heard that you could use a Turbo T5 bellhousing. Any truth to this? Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted July 5, 2004 Share Posted July 5, 2004 Do a search: "T56 l28" and you will know...At least TRY to help yourself... Quote Link to comment Share on other sites More sharing options...
technicalninja Posted July 6, 2004 Share Posted July 6, 2004 Searching "T56 L28" returns 3084 matches. This does not help anyone. It seems that some times the search function causes more issues that it solves. BradMan- If you know of a thread that just deals with L28/T56 please point everyone in the right direction. Thanks Quote Link to comment Share on other sites More sharing options...
JMortensen Posted July 6, 2004 Share Posted July 6, 2004 http://photos.yahoo.com/sss510six If you click on the button right below the search terms that says find all of the search terms then you won't find 20,000 matches (for future reference). I couldn't find the post that had this link by searching for L28 and T56, but I did find it with L28 and 6 speed FWIW. You'll see that it takes a bit more than a bell housing... Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted July 6, 2004 Share Posted July 6, 2004 I just did the search using the option for all terms and the drivetrain forum and got 10 hits... A few in the 6 cylinder forum. Quote Link to comment Share on other sites More sharing options...
Smokey Z Posted July 6, 2004 Author Share Posted July 6, 2004 Thanks for your help Jim. I'll let you know how it turns out! Quote Link to comment Share on other sites More sharing options...
510six Posted July 8, 2004 Share Posted July 8, 2004 http://f1.pg.photos.yahoo.com/ph/sss510six/album?.dir=/15c7&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/sss510six It is much more than just a bellhousing.BTW I am having my T56 rebuilt after about 150drag runs with a 200hp shot of N20 .I am upgrading to a 700rwh conversion. Quote Link to comment Share on other sites More sharing options...
Smokey Z Posted July 8, 2004 Author Share Posted July 8, 2004 What happended to the tranny? or are you just upgrading to be safe? BTW i love your car. It must be a real rollercoaster ride! Randy Quote Link to comment Share on other sites More sharing options...
510six Posted July 11, 2004 Share Posted July 11, 2004 Well,2nd gear syncro started going out and 4th gear was getting a bit notchy ,so I decided to pull the tranny and found the front input shaft bearing to be very loose.After the rebuilder looked it over and found more damage to 1,2,3,4 gears I decided to upgrade to the tune of $1700.Unless you absolutely need the strength of a T56 I would strongly suggest looking at a KA 5 speed upgrade.Quoting the rebuilder "You have a Viper/Corvett transmission and will pay Viper/Corvett prices any time you go to purchace parts". Quote Link to comment Share on other sites More sharing options...
Phantom Posted July 12, 2004 Share Posted July 12, 2004 Not sure the T56 would be of any use behind an L28 unless you have it significantly boosted. The 6th gear .5:1 OD would have the L28 turning 1,500 RPM at 60 with a 3.70:1 differential and standard diameter tires. Th's no where near it's power range and will have you downshifting every time yo start up any kind of a hill. Change the tires to smaller or the differential numbers up and it helps 6th gear but hurts 1st. First is nearly useless even with the 3.70:1 gears in the rear. A good T5 will provide everything the L28 can handle. Quote Link to comment Share on other sites More sharing options...
510six Posted July 13, 2004 Share Posted July 13, 2004 Actually, the T56 that I have works quite well with the turbo 3liter stroker.I use a Toyota CT26 turbo and it provides useable boost at about 3000 rpm and the car pulls hills with no problem in 6th, mabey it is the extra torque from the 3 liter that makes it more tractable.I agree that a NA L28 wouldn`t be happy with a T56. Quote Link to comment Share on other sites More sharing options...
Phantom Posted July 13, 2004 Share Posted July 13, 2004 510six - and you have a motor with excellent low end torque that can handle the overdrive well. That makes my point. A stock L28 isn't going to have that. My L28 had 163 lb-ft of torque at 3,000 rpm - think what it was at 1,500. My LS1 has 290 lb-ft at 1,500 and even it drones when headed uphill at 60-70. Quote Link to comment Share on other sites More sharing options...
spork Posted July 15, 2004 Share Posted July 15, 2004 Not trying to steal the thread here but my question may apply. I've got an 83 280zxt that will be putting 400-450 to the ground and sooner or later, the stock bwt-5 is gonna go. What is my best option for a tranny? The car is almost all drag but still driven occasionally on weekends on the street and as my back up car when the truck has a problem. Obviously money is an issue but I don't want to skimp either if it'll effect the driveability/useability. Isn't there someone running a 2 speed power glide behind an l28? I know I haven't searched on the powerglide part of my question, but would it even be right for my application? So what would be the best choise financially and performance wise? Quote Link to comment Share on other sites More sharing options...
fl327 Posted July 15, 2004 Share Posted July 15, 2004 240zturbo (username) on this site runs a powerglide behind a twinturboL6 For the t5 i would contact gforce transmissions, they do have a website somewhere, and upgrade the internals to the newer 5 speeds that are stronger. I figure this way no adapters or anything would be needed, except for possibly having to use a chevy or ford input spline with a bigger ujoint, now wouldnt that suck? Quote Link to comment Share on other sites More sharing options...
spork Posted July 15, 2004 Share Posted July 15, 2004 I've tried contacting g-force several times in the past, but they won't get back with me...so I gave up...I guess its time to try them again... Quote Link to comment Share on other sites More sharing options...
