Which springs would you use?
Guest 71rb240z
Drax
Which Tokico springs and what spring rates? I have seen them advertised in MSA as 25% stiffer then stock which would be about 125 lb/in. ???
I put the Arizona springs in my V8 240Z and it is a little stiff. The Arizona springs are shorter than stock but are stiff enough (180 front, 200 rear) that the ride height remains stock.
Miles
I'm comparing the eibach pro kit and the tokico advanced handling kit... which include 'generic' tokico lowering springs. I haven't calculated the rates for the 240z, but I am 99% certain they are less than what you'd have with the AZC springs. (if I guessed I'd say ~160-180lb/in for the tokico stuff)
