Guest DueceDawgyDogg Posted December 27, 2002 Share Posted December 27, 2002 Is there a site that sells T56 trannys from a 93-97 camaro/firebird just straight out? And can the tranny from a 93 camaro bolt up to a 98 LS1? Another question I had, can a complete engine/tranny out of a 98 camaro just be swapped in to a Z? Quote Link to comment Share on other sites More sharing options...
Mudge Posted December 27, 2002 Share Posted December 27, 2002 LS1/LT1 T56 isn't the same, sorry. As for just the trans, I haven't seen them, only trans/clutch setup, unless you buy from an individual, other yards out there may sell just the trans I dunno. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted December 27, 2002 Share Posted December 27, 2002 info you might use http://www.drivetrain.com/gmt56inst.html http://www.sallee-chevrolet.com/BorgWarner/bwt56pics.html Listed below are the critical dimensions of the T56 in comparison to T5 and traditional four-speed transmissions. Metric dimensions are converted to inches, rounded off to the nearest 0.1 inch. Trans model A B C D E F GM Super T10, Muncie, Saginaw 6.3 14.2 23.0 N/A N/A 3.75 GM T5 (V8) 6.3 16.0 25.0 19.0 21.2 3.75 GM T56 F-car (production) 4.9 21.0 26.4 21.1 23.9 3.75 GM T56 F-car (aftermarket)1 6.3 21.5 27.0 21.6 21.6 3.75 Notes: 1. Dimensions B through E include 0.5-inch-thick adapter plate Quote Link to comment Share on other sites More sharing options...
Guest DueceDawgyDogg Posted December 27, 2002 Share Posted December 27, 2002 Oh, well if the tranny comes with a clutch then thats cool. I just sort of wanted to see if there was a site that would sell the tranny. Any accesories with it is fine by me. But what about using the complete engine and tranny assembly from a 98 LS1 equiped car? will it bolt right in as "easy" as an LT1 engine and tranny? Quote Link to comment Share on other sites More sharing options...
Phantom Posted December 27, 2002 Share Posted December 27, 2002 Triple D - Do a search of the Chevy V8Z Tech Board using LS-1 as your key word. Several of us are installing the LS-1/T-56 combo into 240 & 280Z's. Quote Link to comment Share on other sites More sharing options...
Mudge Posted December 27, 2002 Share Posted December 27, 2002 In some ways the LS1 swap almost sounds easier, and yes search, very recent topics Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 27, 2002 Share Posted December 27, 2002 Quote In some ways the LS1 swap almost sounds easier, and yes search, very recent topics [smile] Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 27, 2002 Share Posted December 27, 2002 Man I am feeling spoiled since I got my LT1/T56 package for less than you were quoted just for the T56!! Tim Quote Link to comment Share on other sites More sharing options...
Mudge Posted December 27, 2002 Share Posted December 27, 2002 As for cheap I dont disagree, and for kits instead of self fabrication, well for those wanting kits yes, easier in that regard. LT1/T56 combo can be had for $1500 if your lucky, $2000 is about the most I'd pay, but many yards want $2500-$3000, with LS1/T56 setups averaging $500-$1000 more than the LT1 setups, plus more expensive PCM editing, the O2 sim ordeal, all those little things add up! I recall reading someone who said that the LS1 mounts dropped right onto the Datsun Xmember, and at that moment I just thought, wow, lucky dog. But I'll probably go LT1 for the above reasons, if and when I get to do the swap, although the Ford 5.0 is still in the back of my head. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 27, 2002 Share Posted December 27, 2002 Quote although the Ford 5.0 is still in the back of my head. Although, if you have to fab your own mounts anyway, why not go with the higher CI LS1?Oh, WTH, it's all good! Tim Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted December 27, 2002 Share Posted December 27, 2002 Here is another company that sells the T56 tranny. http://www.ddperformance.com/driveline.htm I don't know anything about them except they advertise in Chevy High Performance - can't be bad. Danno74Z LT1/T56 Quote Link to comment Share on other sites More sharing options...
Mudge Posted December 27, 2002 Share Posted December 27, 2002 Quote Originally posted by Tim240Z:[QB] quote: although the Ford 5.0 is still in the back of my head. Although, if you have to fab your own mounts anyway, why not go with the higher CI LS1?QB] Lighter, cheaper, LS1 would be great but the $$$ is depressing. I am also much more familar with the LT1, but $600 rockers for the LS1? EEEEEEEEESH, I'd spend the extra dough for shaft mounted, but still, the hop up stuff is just way expensive, and I dont want to spend LS1 Edit kind of money either. A year down the road though, who knows... Quote Link to comment Share on other sites More sharing options...
flibuoy Posted December 28, 2002 Share Posted December 28, 2002 Ebay has T56 on auctions ....most of the time there is a selection....just type in T56 john Quote Link to comment Share on other sites More sharing options...
Mudge Posted December 28, 2002 Share Posted December 28, 2002 Do you disagree Tim? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 28, 2002 Share Posted December 28, 2002 Mudge, From what I've read (obviously not from experience with the LS1 swap), I would imagine the LT1 to be MUCH easier because: 1. off the shelf install kit (JTR) available 2. Computer editting much easier (Tunercat and LT1Edit) 3. Aftercat O2 sensors not an issue 4. LT1/T56 packages cheaper than the LS1 packages ....Just off the top of my head Tim Quote Link to comment Share on other sites More sharing options...
jeromio Posted December 28, 2002 Share Posted December 28, 2002 Not tryna be picky, but helpful, search for "LS1", not "LS-1". Also, I agree with Tim, but not on all counts. I think the LT1 would be much easier since you can just use the JTR kit. But, editting - the same company that makes LT1 edit makes an LS1 product. Secondary O2s can be left off (and editted out or there are sims). LT1 might be cheaper than LS1, but the corresponding T56 is actually more - the shop I bought my LS1 T56 from for $1100 sells the LT1 T56 for $1500. Higher demand, lesser supply. But yes, I would recommend going LT1 if you want to actually finish your project within a year Quote Link to comment Share on other sites More sharing options...
