Oil pump pick ups
Guest zfan
Never use the standard hammer in type oil pick up. I just fried my sbc 383 because the pick up came loose at the drag strip and my oil pressure went to "0". By the time I caught it I had fried 2 rod bearings and severly discolored my forged I-Beam rods..they really must have gotten hot.
The crank hopefully is ok but will know tomorrow. Rods if salvageable will need to be resized. Crap, 20 part costs alot more to fix. Never again will I use a crappy press in pick up.
Mike
You can purchase one that presses in and at the same time it has a flange attached to the pick up that bolts to the pump. A no brainer for me from now on :lol:
Rick B., aka Ricer Rick lost his in his sbc powered Z but caught it in time to keep from killing his motor.
Mike
#7 and #8 rods were sporting spun bearings but to make matters worse when I pulled the heads I found the valves had contacted the pistons on the intake side :evil: We clearanced everything so I just don't know what went wrong.
Mike
OUCH!
Mike, sorry to hear about that. I think it was Grumpy that warned about that a while ago. I think I'll learn from your mistake and do it differently the first time!! Will you just rebuild the 383 or will you go in another direction?
Davy
I am taking it to the shop today to have the crank turned and the rods resized and balanced. The internals were not to bad. I am purchasing a oil pump with the press in tube but also has a bolt in flang that keeps the pick up in place at all times :oops:
I am using forged four valve relief flat top pistons, they are ok. I think the problem with contact of valves came from the valves being 2.055 and not 2.02 intakes. We checked clearances so I am not sure..Live and learn :oops:
Should be back together and on the road by the end of next week. If matters had been worse I would seriously look into a LS1 :D They can make so much power with so little work.
If I can milk this motor for a year then I will look for a LS1 and rebuild it and stroke it to 383 with a cam change and intake as well. That wouls surely be a beast.
Mike
Guest 77vegasz
Jegs offers a retainer for about $8.00 that will prevent this from hgappening. It clamps around the pick up tube and then bolts to the pump body. I have used one for years and never hap a problem.Its a cheap and effective fix.
Jon
heres an old post that covers most of that info if you read the LINKS!!!!
"Is it as simple as draining the oil, dropping the pan, unbolting the old pump and bolting in the new and putting the pan back on?"
YES AND NO! MOSTLY NO!
yes you drop the pan and install a new pump, but you MUST BRAZE the pickup to the pump AFTER first making sure the pump pickup is correctly possitioned to sit 1/2" MAX to 3/8" min from the oil pan floor , or you have a good chance of it coming loose eventually due to vibration,and you must remove the spring from the oil bye-pass circuit in the pump and replace it after the pump cools, you should make pre-priming the pump much easier by putting some moly grease on the gears before re-assembling the pump. adding a BRACE between the pump body and the pick up is a smart move also.
fill the new oil filter with oil and the pan to the correct level and THEN turn the engine over with the starter without the coil connected untill the gauge reads pressure before starting the engine.
its a good time to use a one piece synthetic oil pan gasket and replace the bolts with studs also. keep in mind a oil pump is only PART of the oil system and getting the oil back to the pan quickly is a good idea, so a windage screen, and a HIGH voluum BAFFLED oil pan is a great idea you might want to add at that time instead of just replacing the stock pan which is FAR from ideal for high rpm performance use!!
the oil pump pick-up on a SB chevy pump is usually a friction fit tube inserted into the pump body with an interfearance fit, it has a tendency to work lose over time if its not brazed (welded) to the pump in HIGH performance applications with their higher than normal vibration levels and stress loads
but before you braze it you must possition the pick-up so its 1/2" from the oil pan floor with the pump and pan installed, this is easily measured by placing modeling CLAY under the pick-up and installing the pan with just the 4 corner bolts to test clearance issues
this is required because the tube can be rotated so that the clearace variers a great deal, if the pickup is closer than about 3/8" it can restrict oil flow, more than about 1/2" clearance and in some extreme cases with low voluum oil pans and it sucks air, if the oil levels low so you need it correctly installed
once you get the pick up installed with 1/2" clearance to the pain floor get it BRAZED in that location to the pump body
things you might want to read
http://kustomauto.2.forumer.com/index.php?showtopic=276
http://kustomauto.2.forumer.com/index.php?showtopic=312
http://kustomauto.2.forumer.com/index.php?showtopic=423
http://www.scuderiaciriani.com/rx7/oil_filter_study/
DON,T BE SCARED OFF ON REPLACING THE OIL PUMP JOB!!
ITS a project ANYONE with minimal skills and a few tools can do if you take your time!
it makes for a great first engine project
you can get a local machine shop to braze the pick-up to the pump REALLY cheaply (under $10 or less in most cases) just use some model clay to determine the correct location/clearance in the pan
http://www.melling.com/highvol.html
I would strongly advise useing FOUR QUALITY JACK STANDS on a LEVEL conctrete surface thou!!
I think youll find these very handy if you work on cars and don,t have a lift
BTW the 12 ton stands are PREFERED as they have a MUCH WIDER BASE and EXTRA STRENGTH,(if IM GOING UNDER A CAR I DON,T WANT TO BENCH PRESS THE DAMN THING TO GET OUT FROM UNDER IT)
how much is you LIFE WORTH,BUY THE ! THE 12 ton RATED STANDS they are MUCH MUCH safer than the 3-6 ton stands IF ONLY BECAUSE THEY ARE FAR HARDER TO TIP OVER IF SOMEONE ROCKS THE CAR! and they DON,T need to be extended to give room under the corvette! in fact they are the perfect height at the first notch when you place them on the frame at the 4 corners of the frame
your NOT looking for the LIFT RATING NEARLY as much as the WIDE BASE, and STABILITY plus the extra safety just thier base to height ratio gives
2 Piece Set
These super heavy duty jack stands will hold most cars and trucks safely over 2 feet off the ground. Perfect for repair work or storage.
Height: 19-1/2'' to 30-1/8''
Base: 12'' x 12-1/2''
Weight: 68 lbs.
THIS ABOVE IS RIGHT OFF THE HF WEB SITE
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=34924
second, thing is IVE used a set of four very similar 12 ton jack stands from NORTHERN TOOL for years, with no problems what so ever
http://www.northerntool.com/webapp/wcs/sto...19&categoryId=0
Torin Pair of 12–Ton Jack Stands
2 heavy–duty steel jack stands at one low price! Double locking pawl and tooth design for extra protection. Minimum height is 18 1/8in. Maximum height is 28in.
In Stock
Ship Wt. 63.0 lbs
Item# 144872
Discount Price... $64.99
Sale Price... $54.99
110% Guaranteed Lowest Price!
youll be getting them at a significant discount if they price match, which they should
