Boost Guage
Guest Joe17
my mech. autometer boost gauge and its fine! works great and reads perfect.
tested on 3 cars.. 2 of which that had electronic gauges before and my mech one read the same..
mike
Guest bastaad525
Same gauge that I'm using.
You know... I had the chance to verify the gauges accuracy at the dyno, they had a thing they could hook up to read boost as well, but I didn't have any free vacuum ports :P Seems pretty accurate though, I know when I first installed the turbo motor and had it set to stock boost the gauge read about 6.5psi which is just about right.
No proublems with my with the two different Autometer mechanical boost gauges that I've had. I now have 4 Autometer gauges in the car and have no proublems with them. The only proublem I've ever had was with my EGT gauge and that was because I didn't have a good ground wire for it. Changed my ground from the factory wire to a spot in the dash and have had no proublems since. :-D
