Turbo Swap Update
Sean73
Here's where I am at so far. 400 miles on this setup. Breaking it in at 7-10 psi.
L28ET F54/P90, Stock Rebuild
P79 flattop pistons (8.8:1 CR)
Deves Rings
Clevite Bearings
Fel-Pro Headgasket
T3/T04E TurboCharger
57 Trim
.63 A/R Exhaust; clipped turbine, .50 A/R Compressor
Oil & Water cooled through teflon stainless lin
es.
Manual Boost Controller
Saab Viggen Bosch BOV
NPR Intercooler
2.25" mandrel plumbing, ceramic coated
Hosetechniques Silicon Connectors
T-Bolt clamps
Engine Management
1984 300ZX (Z31) Turbo ECCS
Z31 Harness modified for S30 body
Z31 CAS, Chopper Wheel, MAF
Ignition
Crane PS60 Coil
NGK BPR7ES-11 (one step colder) spark plugs gap .040
Custom Taylor spark plug wires
Intake
Custom 3" Intake Plumbing
Mandrel Bent Stainless Steel
Apexi Cone filter
BOV recirculated
modified N42 Non-EGR Intake Manifold
Weber 60mm Throttle Body
Relocated PCV valve
Relocated Air Regulator
Fuel
OEM Z31 Turbo injectors; bench flow tested
OEM 280ZXT Fuel Rail
Mallory low pressure fuel pump (@ tank)
Bosch high pressure fuel pump (@ fuel rail)
Modified 240Z fuel tank w/ 3/8" feed and Custom Surge Tank
Bosch Adjustable FPR
Exhaust
Ceramic Coated Exhaust Manifold
2.5" Custom down pipe, ceramic coated
3" Mandrel bent exhaust
Summit stainless steel muffler
Cooling
Griffen 24x19 Aluminum Radiator
Perma-Cool 16" electric fan
Custom thermostatic fan controls
Suspension
Arizona Z-Car Sport Springs 180/200
Boge Turbo Struts
All polyurethane bushings
Drivetrain
5 speed transmission
RPS Max-Series 2400 lb clutch
3.7 R200 Differential; Viscous LSD planned
Planned: 300ZX CV halfshafts
Brakes
Planned: 300ZX vented rotors & Toyota 4x4 calipers (front)
Planned: MSA rear disk brake kit
Electrical
300ZX Turbo 70 amp Alternator
Interior
Autometer Boost & Air/Fuel
Fully functioning R12 Air Conditioning
New seat upholstery and seat foam
New carpet
OEM gauge cluster
OEM Clock converted to Quartz movement
More pics in my gallery:
http://hybridz.org/nuke/modules.php?op=modload&name=coppermine&file=thumbnails&album=89
Sean
73 240Z Turbo
I thought non turbo pistons, ie flat-tops, had less metal between the top of the piston and the top of the first ring making them more easily damaged with detonation. Was looking at doing the same thing so I am very curious how your setup hold up.
Greg '77 280Z
I thought non turbo pistons' date=' ie flat-tops, had less metal between the top of the piston and the top of the first ring making them more easily damaged with detonation. Was looking at doing the same thing so I am very curious how your setup hold up.
Greg '77 280Z[/quote']
No, that's a myth, i think the P79 flattops (81-83 280ZX) are fine for turbo duty. I don't see any major physical differences between these and turbo pistons, except for the dish, of course.
The early 280Z NA pistons with dish are the weak ones.
Umm, last time I had both side to side like that there was a noticeable difference in the thickness of the piston below the first ring... the turbo one had an extra mm of depth there. I think either the picture isn't showing it right, or you have 2 NA dished pistons there. (or 2 turbo pistons)
Well I took the picture myself, and it is definitely comparing an 81-83 NA piston and a 81-83 Turbo piston. I removed these myself from the junkyard. I wish I would have shown the piston tops. If you look closely, indeed, the pistons are slightly different. You can see that the turbo piston has a stouter pin, and the pin height is lower for the turbo piston. (look how the skirts don't line up). This is because the P79 flattop piston has a little bit of deck height.
A dished 280Z NA piston would clearly show thicker rings, and thinner ring lands when compared to these two pistons. Anyone have a picture?
So, yes, the pistons are different. But I don't see why one piston would be physically stronger than the other if subjected to the same amount of abuse. The rings are the same size, and the ring lands are the same size. The deck height of the P79 piston may cause some extra heat, but I'm not losing sleep over it. I've run 10 psi in 105 degree heat, w/ no detonation on 91 Octane.
I have to be a little more cautious with boost compared to a 7.4:1 CR motor, but I think my boost limitations are governed by the ECCS & fuel injectors, and not the CR.
Sean
73 240Z Turbo
Ah, somehow I missed the fact we were comparing a flattop to a turbo piston, and not a dished piston to a turbo piston. The NA dished piston and turbo piston DO have different thicknessess in the upper ring land. Obviously the flattop NA and turbo don't differ so much. ;)
