Rollcage Question?
Drftn280zxt
Tell me if this could be done. If you hve bars that goback and attach to the rear strut towers and also have a removeable strut tower brace going across. Something that is a little more aesthetically pleasing then a simple bar but would still and ridgity. Is this possible?
peej410 - are your 1/8" metal plates weldd to the floor or are they bolted?
Another question is what is the benefit of bolting a fullcage in a car if you cannot get the cage out of the car is first place?
Thanks for all the feedback guys.
  Quote
Mostly cost.
Its something you or someone with general mechanical skills can do as opposed to having to pay a higher rate for a skilled welder. The roll cage manufacturer can also do a volume production run thus reducing material and process costs. Plus, you don't have to completely strip the interior, remove undercoating, and sound deadener so the cage takes less time to install.
FYI, I just got a price quote of $1200 for a 12 point cage (Through the Firewall and attaching to ALL strut towers & Footers sunk into the rocker boxes ala Mark Icard's car) in cromoly. Of course, I'm giving them a BUNCH of business for Jim's Scarab Pro Touring project, and I've been sending others to them, so I'm not sure how much of a price break they are giving me, but Cromoly in 12 point in 1 5/8th inch .082 thickness is pretty danred good I thought!
Mike 8)
FYI... .082 wall tubing (regardless of alloy) is not legal in any SCCA Solo1, Solo2, or road racing category - except for sedans under 1,500 lbs running in Prod or GT categories. .095 wall minimum for alloy at 1.5" OD. Also, if you're going to use alloy tubing, make sure the builder gets the certifications from the material supplier because you will need that to pass tech.
if you did a removeable strut tower brace then i would put a tube in the cage above the struts but thats just my preferance. for me aesthetics play little part in structural rigidity.
  Quote
if you look at the pics in that page there are no plates on the floor i made a triangle shaped box that the main hoop lands on.
mike, 1200 sounds very inexpensive for a 12 point. i dont know if their hours are less but we just built a spec miata cage that was very extensive and it was absolutely our best spec miata cage yet (we always try to improve things.) it probably cost 2200 for the guy including the seat install which required modifying the transmission tunnel. our first spec miata cage can be found at http://www.tangerineracing.com/miata_cage_photos.htm
this didnt require as much work as our most recent cage which recieved many improvements :)
check out the rest of the page and u can see a bunch of the stuff that i used to work on :) oh and unless specified by the SCCA GCR or the customer (ie.120 wall not 0.95) we always run 1 1/2" DOM .095 tube. depending on the car weight and stuff like that. all of our tube coping is done with a 1 1/2" or 1 3/4" end mill in our bridgeport milling machine and not with one of those tube notchers. make sure to take good look at the the weld joints and such.
i just spent this past saturday at limerock park here in connecticut watching my old boss chris (owner of tangerine racing and CFR) race and having looked at some of the cages in the cars i was horrified by some of the work. so be careful and do your research (not implying in any way that you havent already)
