Thumper Posted September 28, 2004 Share Posted September 28, 2004 Well I just picked up this 83' 280zx turbo. It sat for 2 yrs. I did the basic tuneup spark plugs, wires, cap rotor, thermostat, oil, tranny, o2, etc... The problem is when I turn off the car and try to restart it the car won't start. I look at the plugs and they are soaked so the car is getting floaded. If I wait all night long the next morning it will start right up. I instaleled a fpr with gauge and it is right at 30 psi at idle and 37 at full throttle. When I turn off the car the psi will go down to 20 psi in about an hour. The weird thing is that I unplugged the fuel pump and the car keeps running. It takes 30 seconds or so to die. Then when it does die, without hooking up the fuel pump, I can start it again and it will idle for 30 seconds again. If I give any throttle during this time it dies. The fpr gauge reads 0 psi the whole time this is going on. I will be taking off the fuel rail to make sure the injectors are not leaking but I doubt it since the fuel pressure stays up for so long. Also there is no other fuel pump or fuel lines running to my engine. Thanks for you time and input. Quote Link to comment Share on other sites More sharing options...
J Taylor Posted September 28, 2004 Share Posted September 28, 2004 Probably stays running b/c there is pressure in the tank. Pull the gas cap off and see if it does the same thing. Pull a fuel line off on a hot day and see what it does. After a little while the pressure in the tank builds up and pushes the fuel through the lines. Probably enough flowing to keep it running for a while but not enough to feed the motor when you rev. This has nothing to do with your problem with the car not restarting but may answer your question as to why it still runs with the fuel pump unhooked. JT Quote Link to comment Share on other sites More sharing options...
Thumper Posted September 28, 2004 Author Share Posted September 28, 2004 Ok heres an update. The car when cold will run intill it fully heats up 6-8 minutes idleing. Also it will run with all the fuel lines disconected from the fuel rail. It will not run if the injector caps are unplugged. There was no fuel going to or from that fuel rail I swear. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted September 28, 2004 Share Posted September 28, 2004 Run to the patent office! Dont walk. Sorry but I couldnt resist. Quote Link to comment Share on other sites More sharing options...
Thumper Posted September 28, 2004 Author Share Posted September 28, 2004 lol yep and I'm going to make millions. Well still having the same problem please help. Thanks Quote Link to comment Share on other sites More sharing options...
andrei Posted January 21, 2025 Share Posted January 21, 2025 I have a Mazda cx5 from 2013 and i unplugged the fuel pump but the car seems to be running forever. The car is telling me i have no fuel but i waited for 20 minutes, even went for a short trip to release the preasure but nothing. The car still wont shut off. Is there someone in here that can help? Quote Link to comment Share on other sites More sharing options...
jhm Posted January 21, 2025 Share Posted January 21, 2025 2 hours ago, andrei said: I have a Mazda cx5 from 2013 and i unplugged the fuel pump but the car seems to be running forever. The car is telling me i have no fuel but i waited for 20 minutes, even went for a short trip to release the preasure but nothing. The car still wont shut off. Is there someone in here that can help? First off, welcome to the forum. While the purpose of this site is to discuss technical topics that pertain to the modification of the Datsun/Nissan Z cars (240Z, 260Z, 280Z, 300ZX, 350Z), we welcome car enthusiasts of all brands and manufacture. While you are perusing the forum, please take a few moments to familiarize yourself with forum Rules and Guidelines, found here: https://forums.hybridz.org/topic/111201-hybridz-forum-rules-read-now-before-posting/ Second, you are posting to a discussion thread that hasn't been active for over 20 years. Rather than "necroposting" on a 20-year old discussion thread, it may be more useful/productive to begin a new discussion thread for your specific/current issue. Finally, you may have more luck with your specific/current issue on a forum for Mazda cars or Mazda CX-5s. There seem to be a plethora of those -- a quick Google search yielded the following results: https://www.mazdaforum.com/forum/mazda-cx-5-54/ https://mazdas247.com/forum/categories/mazda-cx-5-forum.549/ https://www.cx5forum.com/ https://www.cx50forums.com/threads/cx-5-forum-all-new-forum.1407/ Not trying to discourage you from HybridZ; but any of these Mazda forums would probably yield more fruitful results in resolving your CX-5 technical issues and problems vs a forum dedicated to the Datsun Z sports car. Quote Link to comment Share on other sites More sharing options...
