Windshield and rubber gaskets/moulding?
Louiem
A junkie tried to sell me an old one for $150. Fortunately I checked out a local auto glass place in Dallas and paid $100 for a new tinted windshield. I was amazed at the price. It worked great but was a strugle to get in. Make sure you use the tricks of the trade which include:
- string or coaxial wire around the channel of the rubber gasket. You leave in the channel and then pull out as you set in metal sill.
- Use liquid soap as a lube.
- Rubber around glass first, then set in metal sill, then pull on wire or thick string to set.
Hope this helps
Ferd
Also a trick I've heard and not yet tried, install the SS trim into the rubber before you install the glass. (leave the corner peices out) It helps keep the rubber in the right shape and is 500x easier installing it before than after the window is in place.
