slownrusty Posted October 14, 2004 Share Posted October 14, 2004 Wow guys....you are both depressing me here (James and Jeff)...one day I will have that kind of talent (yeah right) for the time being I am still trying to figure out how to get my cigarette lighter working... Yasin Quote Link to comment Share on other sites More sharing options...
stony Posted October 14, 2004 Share Posted October 14, 2004 Its a 6 into 1. I will answer that part for him but let him respond to the source.... I was going to go that route' date=' but went with the twin set up, mainly for low speed responce, and mostly for the WOW factor... [/quote'] Thanks joel got the source :> Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted October 15, 2004 Author Share Posted October 15, 2004 I ran the final tube last night. However, it was done at my buddies shop and when I did the fit on the car it is too close to the valve cover. No worries, chopped off the tube and rotated it away from the valve cover for clearance and I will rerun the short piece I cut out this weekend. Cut the front of the intake plenum to angle the TB correctly before I weld on the TB plate and finally mounted the intercooler permanently. Can now run the IC piping. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted October 15, 2004 Share Posted October 15, 2004 Cool!!! Quote Link to comment Share on other sites More sharing options...
Vintage-TechZ Posted October 15, 2004 Share Posted October 15, 2004 Looks even better now James (of course ) I think it would certainly confuse a "Lab Rat " though ! lol. Just curious to the final "WEIGHT" of the header ?? Were you after a "Equal Length" header in the end as well,or mainly just "Packaging" where you wanted it in front of the shock tower ?? ..................Vince Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted October 15, 2004 Share Posted October 15, 2004 i think it looks great! question.. which im sure is a stupid one but im a newb.. does the turbo put any stress on the manifold itself? is there any bracing required so the manifold wont crack. sorry if a stupid question. mike Quote Link to comment Share on other sites More sharing options...
Guest Aguyandaredhead Posted October 15, 2004 Share Posted October 15, 2004 Yes the turbo will be a load on the welds and tubing on most custom turbo headers. Mine has a stud on the turbo flange that I will make up a sorta short tie rod that will brace it to the motor mount.. This will eliminate most of the excess weight of the turbo.. Chime in on your setup 240ZTurbo but I would assume you are planning something very close to the same. Jeff Quote Link to comment Share on other sites More sharing options...
