Mikelly Posted November 23, 2004 Share Posted November 23, 2004 Guys, I'm starting to focus on setting up these GForce T5 transmissions on the Chevy motors and I've ordered one lakewood bellhousing specifically set up for the T5. I'm now trying to source either a slave cylinder or Hydraulic release bearing setup... What are you guys running... Mike 8) Quote Link to comment Share on other sites More sharing options...
Pyro Posted November 23, 2004 Share Posted November 23, 2004 I'm using the stock T5 slave clyinder with a 7/8" wilwood master clyinder. I have used this setup for almost ten years without any problems. I'm using a heavy clutch so I had to run a support bracket from the firewall to the inner fender to reduce firewall flex. FYI, I had to cut the lower lip off my lakewood bell housing to gain ground and exhaust clearance. Quote Link to comment Share on other sites More sharing options...
wheelman Posted November 23, 2004 Share Posted November 23, 2004 I'm going to be using a stock slave cylinder and aluminum bellhousing with a 3/4" willwood master. Haven't got it installed yet so can't say how well it will work. Wheelman Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted November 29, 2004 Share Posted November 29, 2004 I am wondering the same. I would like to use the TOB for simplicity... Will be watching... Quote Link to comment Share on other sites More sharing options...
jt1 Posted November 29, 2004 Share Posted November 29, 2004 Mike, I'm using a McLeod hydraulic throwout bearing in mine. After some initial problems with a leaking o-ring, it's been doing a great job. John Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted November 29, 2004 Share Posted November 29, 2004 Mike, I'm using the stock Chevy aluminum bellhousing, stock slave cylinder and a 7/8" Tilton master cylinder. I bought one of the 5 spped Camaro Lakewood bellhousings but when I bolted it up, I saw that the big flange on the bottom was going to ruin my ground clearance, so I returned it. Are you planning on chopping off some of that extra meat on the bottom to help with the ground clearance issue? Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
Mikelly Posted November 29, 2004 Author Share Posted November 29, 2004 Mike, I probably will if it hangs down as much as I suspect it will... I got the thing in the mail on Friday and it is HUGE! I'll mock it up and see how much lower than my headers it hangs, and go from there... I've got a Wilwood 7/8th Master, and I'd like to use the traditional slav ecylinder design because my darned Vette Hybraulic release bearing is a BIATCH to bleed, so I assume the others on the market (About $200) are not gonne be any easier! I'm fighting with my wireless network tonight, have a business meeting tomorrow night, and then will moch everything up between wednesday night and Thursday. I'll take lots of pics as ussual! Mike Mike Quote Link to comment Share on other sites More sharing options...
