Cobra R 17x9 24mm oem, Weight
I don't know if you are talking about the front, rear, or both but I run a 275 on a 9" wheel in the rear. My offset works out to be 25mm if you subtract my .300" spacer and the rear rotor hat that is .100" thicker than the stock drum. If you run an 8" coil and don't mind trimming the fender you shouldn't have a problem fitting a 275's too. I run a 245 in the front on an 8" with out CO's. There is alot more room up front.
You can run 255s. I have a pair on the back of my Z on stock 2003 Ford Mustand wheels with no problems at all. THey even clear the fender lip. You can see pics of the car at: http://pg.photos.yahoo.com/ph/dat74z/album?.dir=3b79&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos
Scroll through the Zcar pics... When you see the stock bodied car with the painted silver wheels... thats them!
Mike
