This turbo anything?
pjo046
http:// http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33742&item=7941060363&rd=1&ssPageName=WDVW
Is this something? It's not watercooled though, something I'd like to prolong it's lifetime. Also I'd really like a turbo with an internal wastegate, so I wouldn't have to modify the exhaust manifold and downpipe etc...
But how will this one perform on a L6 (When it comes to lag, spool up time etc)
This one might be even better?
http:// http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33742&item=7941195317&rd=1&ssPageName=WDVW
This has watercooling, and supposedly ball bearings as well? Has 0.5mm shaftplay though, don't know if that has anything to say? Also, how will this one perform on a L6 engine???? Is this one overkill if I want a responsive turbo that kicks in quite early?
Try Alex Costa, he sent me a rebuilt T3/TO4B setup that fit the exhaust manifold and downpipe perfectly. All I had to do to make it fit was a larger intake tube and bend the wastegate actuator arm and bracket to line up. He is "zcarsmakemyheadhurt" on this forum. Reasonable price and good lead time.
This has watercooling' date=' and supposedly ball bearings as well? Has 0.5mm shaftplay though, don't know if that has anything to say? Also, how will this one perform on a L6 engine???? Is this one overkill if I want a responsive turbo that kicks in quite early?[/quote']
This one says T70 compressor wheel but it's 7 bladed like a 60-1 or 62-1. T series whels are 6 bladed. With that small error I would doubt if it's even BB. With the stage 3 it would spool pretty soon on an L28 though. Ball bearing turbos have very little. A new bushing bearing turbo will have about twice the shaft play than a well used BB unit. Some play is neccesary. Without seeing it first hand it's hard to trust someone say it's BB though. As long as the wheel isn't touching the housing It will be OK. I recently bought a T66 on Ebay. I replaced the bearings and compressor and turbine seal for under $25and now it's as good as new.
Joel, that turbo you linked, it's not a 57 trim. 57 trim got almost 3 inch major with 2.228? inducer. Also standard 57 trim comes in a .60 housing.
Actually took a turbo just like that apart and found 42 trim with some odd 12 blade turbine wheel. I would say stay away from it.
Also, I would stay away from a used Turbonetic turbo. Their BB is not same as Ballistic concept by Garrett and it really doesn't work. Looks like 60-1 with stage V wheel.
Joel' date=' that turbo you linked, it's not a 57 trim. 57 trim got almost 3 inch major with 2.228? inducer. Also standard 57 trim comes in a .60 housing.
Also, I would stay away from a used Turbonetic turbo. Their BB is not same as Ballistic concept by Garrett and it really doesn't work. Looks like 60-1 with stage V wheel.[/quote']
Yes Yo, I was just showing the first link I came upon, to try and make the point that a new turbo can be had for close to the price that guy wants for a unknown cond. / type used turbo...
:shock:
