David K Posted May 28, 2002 Share Posted May 28, 2002 does anybody in SoCal have a dual carb or triple carb setup laying around i can borrow for a few months? my F/I is giving me too many problems and i need something primitive. I will come and pick up if need be. Im in Long Beach and i promise you will get the setup back when i convert to all new turbo f/i setup. i also need the linkage. thanks guys. David Karey SoCalZ Prez Quote Link to comment Share on other sites More sharing options...
Mikelly Posted May 28, 2002 Share Posted May 28, 2002 David, What is the FI system doing??? I've got a complete setup, including wiring harnes and ECU I can sell you cheap... It worked when removed from the car, so you should be alright... Mike Quote Link to comment Share on other sites More sharing options...
Owen Posted May 28, 2002 Share Posted May 28, 2002 Hiromi might have one. He's a CSULB student so he should be close by. I think he might be in Japan at the moment though?! Hiromi, where are you??? Owen Quote Link to comment Share on other sites More sharing options...
David K Posted May 28, 2002 Author Share Posted May 28, 2002 it runs fine on the street. when i get on the freeway, after about 10 minutes it starts putting and missing. if i give it FULL throttle then it seems ok. but when i let off full and try to cruise, it starts missing bad. when i get off the freeway and stop at a light, it is running like it is on 4 or 5 cylinders. after about 5 minutes of street driving, it is back to perfect. i dont know what the hell is going on. ive been in that engine bay for days trying to figure out what it is. its pissing me off and i feel like redlining the damn engine and blowing it just to move onto my new motor sooner. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted May 28, 2002 Share Posted May 28, 2002 Check out your vacuum advance on your distributor. If it is sticking or the diaphram is broken, switching to a carb set-up won't help you out. Just thought I'd throw that out there just in case Quote Link to comment Share on other sites More sharing options...
David K Posted May 28, 2002 Author Share Posted May 28, 2002 i umplugged the vaccumm hose going to the distributor. didnt make a difference. when im on the freeway it sputters like its running out of gas, but i can cruise at 80 no problem. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted May 28, 2002 Share Posted May 28, 2002 Ok, take off the distributor cap, disconnect the hose, not from the vacuum module though, from the other end. OK, here comes the nasty part...using your mouth, apply vacuum to the end of the hose and see if the advance inside moves. You should see some movement of the arm coming from the back side of the vacuum module. If not, try using a screwdriver or something to move the plate the arm attaches to. It is spring loaded, so it should return to the place you moved it from. If that is working properly, apply vacuum to the hose again and put your tongue or finger over the end of the hose to see whether or not the diaphram in the vacuum module is leaking. If the vacuum leaks out, then there probably is a tear in the diaphram. I had a problem similar to yours w/ my carbed 240 and that was where the problem was. regards, mike Quote Link to comment Share on other sites More sharing options...
ZR8ED Posted May 28, 2002 Share Posted May 28, 2002 Hows this for primitive.. have you checked your fuel filter lately? I had a 1 year old filter and thought I was ok.. the car pulled as strong as can be.. took it on the highway..just fine..till I hit 55mph..then it would practically die..and would if I stayed on the gas.. changed the filter..no more probs.. Just an Idea ... Quote Link to comment Share on other sites More sharing options...
David K Posted May 28, 2002 Author Share Posted May 28, 2002 hey guys i tried the distributor thing with my mouth. it works. im just fed up with this. i really want carbs until i get my new motor built and dropped in. i will then get brnad new stuff for the turbo fuel injection. im just looking for simplicity. believe me i have done everything and i know a great deal about the l28 setup but this one has got me. carbs for now. anybody wanna loan them to me? Quote Link to comment Share on other sites More sharing options...
Guest bang847 Posted May 29, 2002 Share Posted May 29, 2002 how long do you need them? i just pulled off a set from a project.. the float is sticking on one of them though... Quote Link to comment Share on other sites More sharing options...
David K Posted May 29, 2002 Author Share Posted May 29, 2002 a few weeks-2 months. thats about it. i need to grab some new parts and thats when i will stick the fuel injection back on. how do i fix a float? i can fix it and then give them back in good condition and cleaned up when im done. thanks Quote Link to comment Share on other sites More sharing options...
Guest bang847 Posted May 29, 2002 Share Posted May 29, 2002 check your private messages Quote Link to comment Share on other sites More sharing options...
David K Posted May 29, 2002 Author Share Posted May 29, 2002 thanks bang. btw, is there something you arent sharing with the group? i noticed the URl to your picture in your signature and i was looking for more pics so i shortened the url to the main website and i got Quote Link to comment Share on other sites More sharing options...
tdab Posted May 29, 2002 Share Posted May 29, 2002 "Is there something your not telling us?" Thats funny! Check out products and then bikini's...the one in the upper left with the lips. Thats my favorite! Bang, you da man! Quote Link to comment Share on other sites More sharing options...
David K Posted May 29, 2002 Author Share Posted May 29, 2002 every man needs his kicks Quote Link to comment Share on other sites More sharing options...
Guest bang847 Posted May 29, 2002 Share Posted May 29, 2002 okay guys i changed it... those arent for your eyes! I maintain that website... oh well moved my stuff off that server. Quote Link to comment Share on other sites More sharing options...
