240zprace Posted February 15, 2005 Share Posted February 15, 2005 comp: 50 a/r housing/ 60 trim wheel turbine: 63a/r housing / stage 5 wheel should i go with 60a/r housing or stay with 50a/r. it's gonna be a custom turbo built by innovative turbo systems. looking to make 350-400 rwhp at 18-20 psi boost. any other thoughts of turbo sizes is welcome also. also, i was thinking of: t3/t04r kahuna, t3/gt35r. help me choose one... Quote Link to comment Share on other sites More sharing options...
yo2001 Posted February 15, 2005 Share Posted February 15, 2005 I've seen 60 trim in .60 A/R with stage V on L28ET. The car went 114-115mph on pump gas. A full weight 280zxt. I recommend it. Quote Link to comment Share on other sites More sharing options...
Clifton Posted February 16, 2005 Share Posted February 16, 2005 A To4R (67mm wheel) is huge compared to your first choice. The GT35R compressor wheel is now used by alot of turbo shops as it is a little better than the 60-1. I think the T3/TO4R is a little big on the cold side and small on the hot side. I would go full T4, that way you have the option of changing turbos if you ever wanted, there are alot more options when going bigger. Here's a few links T4 http://www.precisionturbo.net/turbochargers-display.php?company_id=101795&category_id=3027 T3/4 http://www.precisionturbo.net/turbochargers-display.php?company_id=101795&category_id=3026 Quote Link to comment Share on other sites More sharing options...
white86turboz Posted February 16, 2005 Share Posted February 16, 2005 not to be off the subject but is the ct-26 turbo about the same size as a t04b? do any Z people use the ct-26? Quote Link to comment Share on other sites More sharing options...
Clifton Posted February 16, 2005 Share Posted February 16, 2005 CT26 is about as big as a TO4B S trim wheel, the turbine wheel is a tad larger than the T3 wheel. You would be better off with a stock 280-300zx turbo or a GN turbo. CT26's can't be easily clocked like Garret stuff, they also use a different flange and tend to become very unreliable around 18 psi+. Quote Link to comment Share on other sites More sharing options...
fl327 Posted February 16, 2005 Share Posted February 16, 2005 Anyone try using a FC3S turbo, I was talking to a rotary engine builder about factory turbo cars yesterday and he was saying that the stock turbo on a T2 is the equivalent to a t3/4 Quote Link to comment Share on other sites More sharing options...
240zprace Posted February 16, 2005 Author Share Posted February 16, 2005 A To4R (67mm wheel) is huge compared to your first choice. The GT35R compressor wheel is now used by alot of turbo shops as it is a little better than the 60-1. I think the T3/TO4R is a little big on the cold side and small on the hot side. I would go full T4' date=' that way you have the option of changing turbos if you ever wanted, there are alot more options when going bigger. Here's a few links T4 http://www.precisionturbo.net/turbochargers-display.php?company_id=101795&category_id=3027 T3/4 http://www.precisionturbo.net/turbochargers-display.php?company_id=101795&category_id=3026[/quote'] thanks clifton, i,ll look into these turbos Quote Link to comment Share on other sites More sharing options...
240zprace Posted February 16, 2005 Author Share Posted February 16, 2005 not to be off the subject but is the ct-26 turbo about the same size as a t04b? do any Z people use the ct-26? wht86 turbo, a buddy of mine use the ct26 on a 3litre (L30et) and at 13lb boost, he put down 275rwhp..12.6 in the quarters in a 71' 510 Quote Link to comment Share on other sites More sharing options...
yo2001 Posted February 16, 2005 Share Posted February 16, 2005 CT26 is not cheap to build and rebuild since the parts are not so abandon. I guess that;s one of the reason no one uses one. Quote Link to comment Share on other sites More sharing options...
Clifton Posted February 16, 2005 Share Posted February 16, 2005 CT26 is not cheap to build and rebuild since the parts are not so abandon. I guess that;s one of the reason no one uses one. Parts are actually as easy to get as Garret parts, at least in AZ. They are easier to work on too. No clips holding the bearings in like Garrets. They are just to small. Upgrading them is pointless though. Quote Link to comment Share on other sites More sharing options...
white86turboz Posted February 16, 2005 Share Posted February 16, 2005 Buddy of mine wants to sell me a brand new ct-26 turbo for $100, I think I'll buy it just to **** around wit it lol Quote Link to comment Share on other sites More sharing options...
510six Posted February 16, 2005 Share Posted February 16, 2005 You will need to have an adaptor fabricated to use the CT26 on a T3 exhaust flange.I just had a adaptor made to use a T3 flange on my manifold that was setup to use a CT26.If your just looking for a buget turbo and aren`t looking for more than 300rwh the CT26 is a decent choice and it has a water cooled center section that makes it nice on a street driven car. Quote Link to comment Share on other sites More sharing options...
white86turboz Posted February 16, 2005 Share Posted February 16, 2005 Yeah I'm thinking of buying an old 280 turbo project car, then put the ct-26 on + this MK3 intercooler that I'm not gonna use for my 86' turbo Z. So it'll be fun building a Z project turbo car. Quote Link to comment Share on other sites More sharing options...
aarang Posted February 16, 2005 Share Posted February 16, 2005 I have a 57 trim E wheel with a .63 a/r stage V in my car ( 280zxt). I tried both the .60 a/r comp housing and the .50 comp housing. The only real diff I noticed between the two ( at least on my car) was that the .50 housing started to turn into a restriction on the top end (18 psi) as compared to the .60. This is from my "seat of the pants" dyno! The .50 housing doesn't require a spacer on the exhaust flange, either. I like the .60 better. Either way, it is a fantastic turbo IMO. My $.02 Aaron Quote Link to comment Share on other sites More sharing options...
240zprace Posted February 16, 2005 Author Share Posted February 16, 2005 I have a 57 trim E wheel with a .63 a/r stage V in my car ( 280zxt). I tried both the .60 a/r comp housing and the .50 comp housing. The only real diff I noticed between the two ( at least on my car) was that the .50 housing started to turn into a restriction on the top end (18 psi) as compared to the .60. This is from my "seat of the pants" dyno! The .50 housing doesn't require a spacer on the exhaust flange' date=' either. I like the .60 better. Either way, it is a fantastic turbo IMO. My $.02 Aaron[/quote'] thanks for the info... Quote Link to comment Share on other sites More sharing options...
240zprace Posted February 17, 2005 Author Share Posted February 17, 2005 spoke to tech rep. from cheapturbo.com and he would work out a price for me... 1. GT35R turbo ( ball bearings) 2. 2- T3 flanges 3. 3"- 4 bolt flange 4. 44mm Tial wastegate all for $1799 shipped to my door. do you all think this is a good buy? by the way, has anyone on this board used this turbo on a L28et.. Quote Link to comment Share on other sites More sharing options...
