Puzzler for the day
Guest greimann
I have no idea. Perhaps calling it a radiator is erroneous because the IR radiation emitted is an extremely small portion of the total amount of energy removed by conduction with the air passing between the fins and tubes. Without the air passing through it, it doesn't work very well as it is an extremely inefficient emitter or radiator of heat?? Black box stuff here maybe.
Guest greimann
Yep, you all are on the wave length (a little radiation humor there).
Very little heat in an automotive radiator is lost due to actual radiation. The vast majority is due to conduction of the water to the tubes and fins, and then conduction of the fins to the air flow. That is why it is important not to paint the fins and tubes because the paint insulates the tubes and inhibits the heat conduction. Copper-brass radiators are painted for anti-corrosion and cosmetic purposes with a special thin paint. Aluminum radiators are protected with an invisible cladding or anodizing.
Even in old houses with hot water heat, the radiator is a conductor and the warm air travels throughout the room via convection.
How the whole radiator misnomer got started is anyone guess, but it happend years ago and we are stuck with it now.
Well lets check with Webster and see what he has to say... Definition:
Radiator:
Pronunciation: 'rA-dE-"A-t&r, dial 'ra-
Function: noun
Date: 1836
: one that radiates : as a : any of various devices (as a nest of pipes or tubes) for transferring heat from a fluid within to an area or object outside b : a transmitting antenna
Sounds about right according to the definition at least. *Shrug* :D
Regards,
Lone
