Need new injectors...
badjuju
i'm looking for a set of injectors that will (hopefully) run faster rates than stock 280zx turbo injectors. I would, however, settle for anything at this point because I recently discovered I'm using 3 different types of injectors. the afm is bumped way up to keep from noticing the difference in flow, and that is causing corrosion of my plugs. HELP! What model injectors will fit into my mani without modification? I was thinking 300 zxzxt injectors, maxima, what others?
