sulla Posted April 4, 2005 Share Posted April 4, 2005 I just stumpled onto the The Falconer V-12. The specs are... 800 HP 780 ft-lb Torque 90 degree V-12 600 cid 1 Motec ECU Runs on pump gas Low weight, 500 lbs Accepts Chevy bell housing and front mounts http://www.falconerengines.com/prod04.htm I like the one on the bottom with the satin finish. Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted April 4, 2005 Share Posted April 4, 2005 I see dollar signs! Quote Link to comment Share on other sites More sharing options...
Chewievette Posted April 4, 2005 Share Posted April 4, 2005 Awesomw idea!!! I have pictures of a Falconer V12 installed in an 80's corvette, now that was sweet! If you've got the extra $10,000+ Go for it! I know I sure dont... Quote Link to comment Share on other sites More sharing options...
Dnaught14 Posted April 4, 2005 Share Posted April 4, 2005 sooner or later someone always finds this site and posts it. You would have to do lots oof body modification in a car with that powerplant. Ther problem isnt the hp it makes, but the tq at low rpm. You would make a z look like a twizler with that engine in it. Granted if you have the money to put that in a car, reinforcing your frame shouldnt be an issue. I like the indy engine that he has made streetable. That would be a fun car to drive around. Quote Link to comment Share on other sites More sharing options...
sulla Posted April 4, 2005 Author Share Posted April 4, 2005 Oh I am not really thinking of trying to get that motor for a Z. By the time you made it work you would have a complete new car. But it would be a good motor for a custom kit car of some kind with a space frame made to handle it. Quote Link to comment Share on other sites More sharing options...
(goldfish) Posted April 5, 2005 Share Posted April 5, 2005 -560 FT.LB. TORQUE AT 1500 RPM thats what i'm talking about Quote Link to comment Share on other sites More sharing options...
Chewievette Posted April 5, 2005 Share Posted April 5, 2005 Well as long as we're all fanticizing(sp?) here, I should probably add this: I dont know anything about the engine except that its GM, yay! and it has an INSANELY Complex intake manifold!! I'd LOVE to see the molds for that Carbon Monster! Quote Link to comment Share on other sites More sharing options...
dot Posted April 6, 2005 Share Posted April 6, 2005 I like the northstar. Timing chains in the back are a nice touch. Where’s the water pump? Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted April 6, 2005 Share Posted April 6, 2005 I could be wrong, but, it looks like there's a water outlet hose and a heater hose (or other cooler hose) behind the left header towards the very back of the engine. Look between the #7 and #9 header tube (4th and 5th header from the front of the engine) Quote Link to comment Share on other sites More sharing options...
dot Posted April 6, 2005 Share Posted April 6, 2005 awd92gsx That looks like a real hot spot for a hose, but I think your right. Quote Link to comment Share on other sites More sharing options...
Chewievette Posted April 6, 2005 Share Posted April 6, 2005 dot said: Timing chains in the back are a nice touch. They usually do that on mid engined cars dont they? Quote Link to comment Share on other sites More sharing options...
dot Posted April 7, 2005 Share Posted April 7, 2005 You might be right. There aren’t a lot of accessory mount points on the front. I don’t anything about this motor. What’s it for, a 24 hour car? In a Z it would help move the weight back. Quote Link to comment Share on other sites More sharing options...
