EvilRufusKay Posted April 8, 2005 Share Posted April 8, 2005 I am getting ready to install my hatch which I plan to weld in place. Then I remembered that I need a new seal. Does anyone have a thought on a non-oem replacement that could work? Something I could grap at a local parts store that might fit? I am planning on installing the hatch Sunday and don't have time to order one from MSA. I thought someone posted something about this but my search did not pan out, though I plan on trying again. I do have a brand new rear hatch seal for a 94 Jimmy that I bought but never used. I may try to cut that up and use it. Thoughts? Rufus Quote Link to comment Share on other sites More sharing options...
dot Posted April 8, 2005 Share Posted April 8, 2005 Hey Rufus: I searched last week and came up with someone recommending a seal off a 240 SX. I was going to try the one off my Grand Cherokee. I haven’t measured it for length yet, but the molding has the right cross sectional shape. Quote Link to comment Share on other sites More sharing options...
fl327 Posted April 8, 2005 Share Posted April 8, 2005 I used 300zx weatherstripping for the hatch seal in one of my cars, worked well just had to trim a foot or so off of it. Had to slam the hatch shut hard to get it to close, left it overnight and it closed normally after that, figured that was a good sign. A lot of the nissan cars use the same type seal on the hatchback but different sized depending on the car, just had access to a 300zx seals for free and thats probably the only reason I used it over anything else. Isuzu impulse weatherstripping works good on the doors. Quote Link to comment Share on other sites More sharing options...
EvilRufusKay Posted April 8, 2005 Author Share Posted April 8, 2005 Thanx guys I will look into those. I found the post I was talking about: http://forums.hybridz.org/showthread.php?t=84379&highlight=rear+hatch+seal Hi Owen. Try McMaster Carrwww.mcmaster.com[/url'] page 3181 item#1120A33 I got the 25 foot roll. each door takes 11 1/2 feet. I got that info from Pierre Z in Hawthorne. Unfortunately I wouldn't be able to get it before Sunday so your advice may just be the ticket. First I will try my Jimmy strip. Thanks again! Rufus Quote Link to comment Share on other sites More sharing options...
Jolane Posted April 9, 2005 Share Posted April 9, 2005 Why do you need a seal when you are welding it in? Am I misunderstanding? It seems like you would just seal it by welding it solid all around. What is to seal after this? Thanks, Joshua Quote Link to comment Share on other sites More sharing options...
EvilRufusKay Posted April 9, 2005 Author Share Posted April 9, 2005 Why do you need a seal when you are welding it in? Am I misunderstanding? It seems like you would just seal it by welding it solid all around. What is to seal after this?Thanks' date=' Joshua[/quote'] Joshua, I agree that is what I was thinking however, I am afraid of fumes. I suffered from them so bad that it has me wondering. Also, even though I am welding "most" of it closed (left that part out) the center of it will still open/close. I am basically narrowing the rear window. My CAD drawing wont open. Maybe someone could post it if I send it to them? Quote Link to comment Share on other sites More sharing options...
Jolane Posted April 9, 2005 Share Posted April 9, 2005 I see. Watch that heat around those seals! Joshua Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted April 9, 2005 Share Posted April 9, 2005 yeah or you'll get a totally different kind of fumes and IMO burning rubber smells worse than Z stink if you're going to weld it in, why not just use some of the generic weather stripping that you can pick up someplace like autozone? Cheap, cut to length and should work great and be quick to get. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted April 9, 2005 Share Posted April 9, 2005 Ok.. if your welding it in place... how do you plan to replace the rubber when it dry roughts out on ya? The welding heat is gonna shorten the life spand of it. It'd be smarter to just wled it then inject some silicon caulk, would seal better too. -Ed Quote Link to comment Share on other sites More sharing options...
Jolane Posted April 9, 2005 Share Posted April 9, 2005 If the parts are not moving, the RTV idea sound great! Excellent Idea! Joshua Quote Link to comment Share on other sites More sharing options...
