Guest ZDreamin Posted September 15, 2002 Share Posted September 15, 2002 hey all my friend told me about this stuff and it seems crazy, the marvel mystery oil people recomend using their stuff in both the the gas tank as a fuel addative and also into the crankcase as an oil addative, this seems crazy, any body know what this dual-purpose stuff is or ever used, this is purely a question out of my own curosity. have a god night ladies and gentlemen Quote Link to comment Share on other sites More sharing options...
spotfitz Posted September 15, 2002 Share Posted September 15, 2002 Works great in SU's aswell! Quote Link to comment Share on other sites More sharing options...
labrat Posted September 15, 2002 Share Posted September 15, 2002 I think it's supposed to act as an upper cylinder lube when put into your gas to lube intake valves. In the crankcase, it's supposed to clean varnish off of lifters and stuff. All i know for sure is that it works great when used to oil air tools. Bill Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 15, 2002 Share Posted September 15, 2002 Yeah, its been around a hundred years probably haha. Its as they say supposedly a wonder cure for things like sticky lifters and stuff. Its actually a decent lubricant for oiling things with, but I wouldn't put it in the fuel injection system on more modern cars unless it says its O2 sensor safe which I doubt it is. Thats about all I know about it, I guess if I knew more though, it wouldn't be a mystery huh? Regards, Lone Quote Link to comment Share on other sites More sharing options...
denny411 Posted September 15, 2002 Share Posted September 15, 2002 The stuff is great for older engines with alot of carbon buildup, and sludged up crankcase. It will free up sticky lifters, loosen carboned up rings,and help to clean the fuel and intake system. It also smells good For transmissions that shift "slugishly" try a pint of Berrymans B12 carb cleaner. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted September 15, 2002 Share Posted September 15, 2002 MMO is a detergent-dispersant additive that can clean carbonaceous residues from engine internals. It can boost the d-d components already in your engine oils and if used in the fuel, can clean deposits from valves. Premium fuel also conatins higher levels of detergent additives, so if you have been runnning that, MMO is probably unnecessary in the fuel. The best defense is a good offense, and using synthetic oils that have a higher oxidation resistance than conventional oil is the best defense against deposits. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted September 15, 2002 Share Posted September 15, 2002 Had a motor in a 73 Celica that was in pretty bad shape...been sitting for two years... I filled the tops of the cylinders with the stuff, until it ran out of the spark plug holes, and then let it sit for two days... I went back and took a breaker bar and freed up the stuck rings... We fired the motor up and the compression was above 150 on all four cylinders... and I ran that motor back and fourth to high school and college for about 16 months before the Timing Chain finally let go! Crazy stuff, and I've had guys call me a liar because of that story, but it is true, and I wouldn't have thought to use the stuff had it not been for my dad! Mike Quote Link to comment Share on other sites More sharing options...
denny411 Posted September 15, 2002 Share Posted September 15, 2002 I try to have at least two quarts on the shelf at all times Quote Link to comment Share on other sites More sharing options...
Cruez Posted September 16, 2002 Share Posted September 16, 2002 I just put some of it in the Z the other day since its been sitting for a year...(I am STILL waiting on a part ) Quote Link to comment Share on other sites More sharing options...
Guest Perry Posted September 16, 2002 Share Posted September 16, 2002 If any of you do radio control stuff I used to work in a hobby shop and discovered that "After run oil" which you pay about a dollar per ounce for is actually MMO which you can get a giant can of from Wal-mart for a few bucks. Works great at keeping rust out of the little nitro engines. Perry Quote Link to comment Share on other sites More sharing options...
Cruez Posted September 17, 2002 Share Posted September 17, 2002 wow Perry, didn't know that.... And I have a gas R/C car.... Thx Quote Link to comment Share on other sites More sharing options...
