Xander Posted April 25, 2005 Share Posted April 25, 2005 Hi, I recently started loosing oilpressure on my rebuild l28et. After removing the oilpan (I though it might be a loose oil pickup tube) I found that the inside of the oilpan that used to be black was now shiny metal. The paint chips where clogging up everything. I never painted the inside of the pan. It was the original nissan paint but still it peeled off. What could cause this to happen? After the first rebuild I used a very cheap 15w40 supermarket oil. I slowly drove the car for 500 km just to setup my megasquirt and to breakin everything nice and slowly. After that I switched to a semi synthetic 10w40. Quote Link to comment Share on other sites More sharing options...
frank280zx Posted April 25, 2005 Share Posted April 25, 2005 Xander did you clean the oilpan with something prior to install, like brakecleaner orso ? Quote Link to comment Share on other sites More sharing options...
Xander Posted April 25, 2005 Author Share Posted April 25, 2005 hmmm... good point frank. I probably did use a solvent to clean it. Quote Link to comment Share on other sites More sharing options...
frank280zx Posted April 25, 2005 Share Posted April 25, 2005 hmmm... good point frank. I probably did use a solvent to clean it. I hope not that stuf out of that big blue canister you used to have in your kitchen ( yes that stuff that had green fumes) anyhow did you check the damage ? call you in few Quote Link to comment Share on other sites More sharing options...
Tony D Posted April 25, 2005 Share Posted April 25, 2005 was the inside of the pan painted at all? I think the last on I pulled was bare metal... In any case, the only paint I have ever used [/i]inside[/i] the engine peoper is Glyptal (red electrical insulating varnish). Google Glyptal, and you should find it. It is good for sealing up a freshly-hot-tanked engine block. Quote Link to comment Share on other sites More sharing options...
Xander Posted April 25, 2005 Author Share Posted April 25, 2005 I spoke to an engine builder today and he said that synthetic oil can do that to paint. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted April 26, 2005 Share Posted April 26, 2005 the paint was peeling in my oil pan so i had it hot tanked to remove all of the paint.probably wont put any kind of coating on inside of pan. Quote Link to comment Share on other sites More sharing options...
