Need information on OS Giken trans gears...
Guest JAMIE T
Guest JAMIE T
Hey guys, I'm trying to find out what gear ratio's would possibly be in my transmission. It's an RB25DET trans with an OS Giken gear-set. That is all I know, it is what I'm told. I have no reason to believe otherwise. I just don't know what ratio's it is or how to find what ratio's were offered. Thanks.
Guest JAMIE T
Yeah, that's what I'm thinking. Damn...
Maybe it work out ok and just keep me in boost longer? Probably OK, but not optimal.
I think a better ratio would be 4.10's
Guest JAMIE T
That's a good question. I've not been able to find ENOUGH information about it on the web. That's why I turned here for answers. Matt has been a huge help though and I'm sure he'll know. I DO know that this trans came from behind Stony's NEW motor which has dyno'd over 600 rwhp. So, that's promising.
I've only had one stock RB25 tranny failure, ever. I think it had a lot to do with the rear end failure. The car puts down just over 700whp and likes to tear up R200's in third gear. That's the first gear to get any kind of "traction" at all in this car (275/15 555R's). Anyway, the latest failure locked up the rear hard, just for an instant, probably shocking the hell out of the tranny gears and knocked off a couple of teeth.
I've had several OS failures in 700+whp GT-R's, but it's always the main drive gear, which stays stock in the OS (and most other) sets. Keep in mind that a 700hp GT-R leaving at 9,000 RPM with a tripple is a very traumatic experience for the gear. I've also seen the stock trannys live for quite a long time under severe abuse.
Another weak point (it isn't) is the input shaft on very high power, high traction vehicles. OS sells an aftermarket one. The final weak point is the center plate. It takes a tremendous thrust load in high power cars and sometimes cracks. There are aftermarket ones available.
The gears are the same in the GT-R, RB25, and Z32, so If you're using the Z32 diff, it's not a problem. The 2.6 first will make the gear a little long, but if you have near 500hp+, and are not on drag slicks, it may be a benifit. With a 4.1 or 4.3 on street tires, you ain't goin' nowhere in first or second. ;)
In my 240Z with a Quaife trans I had a 2.39 first gear and even with a 4.38 rear gear the car was hard to get going, especially with a 5.5" double disk clutch. Most of the time it involved a small burnout or a stall.
It was better with a 4.63 and almost tolerable with a 4.88.
