Guest nikko74z Posted May 24, 2005 Share Posted May 24, 2005 Who has pics of their 4bbl intakes. I have a 4bbl intake that bolts to the SU intake. This automatically gives me equal length runners with fuel coming from a central location. My Holley 600 was built by Precision Racing Carbs. These guys are great. The guys in NHRA Pro-Stock run these carbs. The car runs great. It runs the strongest it has ever run. I had Weber 40's on it. They ran strong as well. I would like to get a set of 45's. I have read that the 40's are to small on a stroker. With the holley on my street car, I ran a 12.79. I ran a 12.91 with the webers. I will take a picture of the intake and post it by this weekend. I have an Arizona Z intake on another stroker. I have not been able to get number 1 and 6 to burn as nice as the other cylinders. They run lean when the others are on the money. I have a couple of ideas for a single carb intake. Someone mentioned a dual plane design for BMW. Is that right? I am even considering running two 352 carbs. The idea was suggested by Chris at PRC. Any of you guys have any ideas? Quote Link to comment Share on other sites More sharing options...
Administrators SuperDan Posted May 25, 2005 Administrators Share Posted May 25, 2005 I would really like to see any pictures that you have. SU intakes kinda of puzzle me. This is equal length runners? But this is not? Quote Link to comment Share on other sites More sharing options...
datsunlover Posted May 25, 2005 Share Posted May 25, 2005 I think I've seen the intake he's talking about (bolts to the intakes where the SU's did), but alas.. I can not see how it could be called 'equal length runners' as shown by the pic there.. Quote Link to comment Share on other sites More sharing options...
WHP Posted May 26, 2005 Share Posted May 26, 2005 I am using the AZ 4bbl manifold with a Holly 390 cfm on a stock 2.8 with flat top pistons. It works well. I live at 2800 ft so I had to go down two jet sizes and change the accelerator pump cam to get rid of a bad stumble. The benefits of the 4V are electric choke (no choke cables), no dampener oil to refill, tidier engine bay, and easy to find parts. There are NO cylinder distribution issues with the AZ set-up. I could not tell any power difference over my home rebuilt SU's with the tricks shown in the Z Therapy video. I never had problems with either SU's or 4 bbl once set up properly. Jetting the SU's spot on is a little harder because needle profile is more difficult to modify compared to changing jets, cams, and power valves. BTW, the small main jets needed are not in the standard Holly jet package, they have to be bought in seperate pairs. MPG was unchanged between the two. My case is comparing good SU's to good 4V set-up, not the usual situation. Just my .02. Will Piatt Quote Link to comment Share on other sites More sharing options...
Guest nikko74z Posted May 27, 2005 Share Posted May 27, 2005 I meant when compared to the Arizona Z intake. Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted June 28, 2005 Share Posted June 28, 2005 WHP, I've got the same setup in my 77. I also have a complete Monza exhaust. What size jets do you need for the 390? The PO told me they needed to be jetted down. He already did the Acelorater pump mod. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted June 28, 2005 Share Posted June 28, 2005 I would really like to see any pictures that you have.SU intakes kinda of puzzle me. This is equal length runners? But this is not? From the pictures, I would say the SU intake is closer to equal length than the 4bbl by quite a bit. Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted June 28, 2005 Share Posted June 28, 2005 Nikko..youur manifold adaptation may have been offered by a company called Car Tech. I have found the following companies offered 4 BBL and usually for Holley 390 CFM application for the Z.. Clifford Research 6=8, Cannon, Offenhauser and of course Car Tech. Arizona Z and MSA may be the only company (s) offering the 4 BBl adaptation. I would like to find the Car Tech 4 BBL adaptation on eBay or a classified forum. As for equal length...I will flip a quarter over that since both appear to be an attempt at equal length... Arizona Z won !!! (this time) Quote Link to comment Share on other sites More sharing options...
WHP Posted July 4, 2005 Share Posted July 4, 2005 350Z, The 390 came stock with # 51 main jets. I got best results with #49. Rule of thumb is reduce one jet size for each 1000' altitude increase. Will Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted July 8, 2005 Share Posted July 8, 2005 Thanks. I live around the 1000 foot mark. I was having troubles with mine backfiring when under a slight load, but ran good when the 4 bbl opened. First, I had to undo the PO's screwups and got rid of that huge vacume leak. He had the valve cover hose just hanging, and a PCV valve going to the crankcase. I read the post from ArizonaZ and did it their way. Still had the poping. I got rid of those junk Bosch plugs and put in a new set of NGKs, dropped the fuel pressure down to 3 1/2 from 4, adjusted the floats and the air mixture. All I can say is WOW! This has to be by far the most easiest, and the most reliable szetup on the market today. I'm not going to be in a hurry to tease the twin turbos just yet. Quote Link to comment Share on other sites More sharing options...
