smokingwheels Posted May 25, 2005 Share Posted May 25, 2005 i worked 180B head on L20b engine that ran on a timing curve like this http://us.f1f.yahoofs.com/bc/40c021...zjkCBGK JtEK3t total useless past 3000 rpm with stock dizzy but used to go good with about 25 deg to much advance and never melted the pistons! and what a racket it used to make. in the beging after bolting it down i nearly lifted the roof off the car port trying to start it then The big bang +flash of light. split the mufflers open like they where wet paper bags. was able to arc up in second gear it used to carbon up plugs in about 3 months ,heat range 12 i think i still have a few of them,the bearings in block lasted less than a year i later reduced the comp ratio 8 to 1 this brought the total advance back to 22 deg past 3000rpm. i felt my old engine at 8 to 1 comp had more power than the stock one im running now i also found that changing the L20 cam to a L18 cam made a slight diffrence the knocking was less with the same timing ,but no recorded values . here is some results of my engine i have data recording on accerelation figures on current motor eg 1st gear is about 13 to 14 rpm increase per pistion firing. http://smokingwheels.myphotoalbum.com/view_album.php?set_albumName=2003 my mate ......helped me toss the motor out but we didnt rip the head off im about to start work/recreate this strange thing again on a 4 cyc head in my bluebird which now has a notebook fitted to control the timing. this program has taken over 5 years to complete. i have data recording on accerelation figures on current motor eg 1st gear is about 13 to 14 rpm increase per pistion firing. the computer is not that fast only 200mhz but will run a 4 cyc near 10K rpm just ive got 3 inputs hooked up to change things like vac adv,temp, revlimiter. if my new one runs ok i will port the head on 280zx the same way. Ps: if anybody would like to convert this to english please let me know Quote Link to comment Share on other sites More sharing options...
Silent Posted May 27, 2005 Share Posted May 27, 2005 id love to help, but im so bloody confused as to what is going on. sorry bad joke i know. Quote Link to comment Share on other sites More sharing options...
johnc Posted May 27, 2005 Share Posted May 27, 2005 Proper punctuation and grammer would go a long way to clarifying whatever was posted above. Please read the rules and try to clean up the post so we can all figure out what you're asking: http://forums.hybridz.org/announcement.php?f=76&announcementid=2 4. This site is based in the USA, and as such, text is to be written in English. There are web sites available on the web that can translate text from many recognized official languages to English, if you don't know it. (But then how could you read this? ) Gangster-slang, or any other cute, obtuse, street-talk dialects are not tolerated. Write in clear English that does not require a current knowledge of the latest street-slang. 9. Please try to use correct spelling and grammar. Everyone makes mistakes, but a quick proofread of your post before you hit the "submit" button helps a bunch. Cut and paste your text to/from a Word processor, if you have questions about your spellings. This will help the search function work better as well. Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted May 27, 2005 Share Posted May 27, 2005 A picture worth a 1000 words so i clicked on "My Photo Album"...... I am now mystified beyond comprehension. Your theoretical applications are not working unless you are trying to predict at what RPM an internal combustion engine will implode or explode or both..... or is it melt down. Rocket science or grievance resolution Quote Link to comment Share on other sites More sharing options...
smokingwheels Posted May 28, 2005 Author Share Posted May 28, 2005 A picture worth a 1000 words so i clicked on "My Photo Album"...... I am now mystified beyond comprehension. Your theoretical applications are not working unless you are trying to predict at what RPM an internal combustion engine will implode or explode or both..... or is it melt down. Rocket science or grievance resolution rocket science yes my program measures the acceleration in rpm then predicts where the pistion should be on the next firing stroke it and advances the the timing depending on rpm and rate of increase. (patent pending if i had the money) when the trigger comes say 55 deg before the event there is a small lag if the rpm is increasing. eg if the last input reading was 800 rpm and the current input is 825 rpm there could be an error of of approx 4 deg to fire the correct timing i think of it this way its a lot harder to hit a moving target with the same force as when it is stopped. Quote Link to comment Share on other sites More sharing options...
smokingwheels Posted September 27, 2008 Author Share Posted September 27, 2008 Proper punctuation and grammer would go a long way to clarifying whatever was posted above. Please read the rules and try to clean up the post so we can all figure out what you're asking: http://forums.hybridz.org/announcement.php?f=76&announcementid=2 "require a current knowledge of the latest street-slang" LOL I know my english is not very good, I did my best back then. I have now made video clips of what I have been doing, it sure beats me trying to translate my my facts to English. http://ampair.tripod.com for the story. 7 of my videos have been riped so far on you tube. Quote Link to comment Share on other sites More sharing options...
ozconnection Posted September 27, 2008 Share Posted September 27, 2008 Um, er, yeah, maybe. Please help us to understand what's your aim and how we can help. At the moment, I'm lost on all this and it seems a shame because I can see that you're fairly passionate about something...it's just I'm not sure what it is yet... Cheers mate Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted September 27, 2008 Share Posted September 27, 2008 smokingwheels is a member on classiczcars.com and has an abundance of wild posts that don't make any sense. Search his name and you will have a headache. Quote Link to comment Share on other sites More sharing options...
johnc Posted September 27, 2008 Share Posted September 27, 2008 A reply three years in the making? Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 27, 2008 Share Posted September 27, 2008 LOL three years... Quote Link to comment Share on other sites More sharing options...
smokingwheels Posted September 28, 2008 Author Share Posted September 28, 2008 A reply three years in the making? Lol My project has been 8 years in the making so far Well Ive gone Digital now dont need to type so much. WWW.youtube.com was not around back then! as my old boss used to say "come here please explain!" oh dont search anywhere for video's containing "smokingwheels":) Cheers Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 28, 2008 Share Posted September 28, 2008 http://www.youtube.com/user/smoking2wheels What these videos??? Quote Link to comment Share on other sites More sharing options...
jerryb Posted September 28, 2008 Share Posted September 28, 2008 Thanx for wasting 2 minutes and 12 seconds of my life...NOT!! WTF was that about........... http://www.youtube.com/user/smoking2wheels What these videos??? Quote Link to comment Share on other sites More sharing options...
KillerBjt Posted September 29, 2008 Share Posted September 29, 2008 Uh would you by chance be trying to figure out a way to better control spark timing and fuel consumption? Quote Link to comment Share on other sites More sharing options...
smokingwheels Posted October 2, 2008 Author Share Posted October 2, 2008 A time-out occurred while communicating with the server. Account: 'Fun', Server: 'mail.bigpond.com', Protocol: SMTP, Port: 25, Secure(SSL): No, Error Number: Quote Link to comment Share on other sites More sharing options...
smokingwheels Posted October 2, 2008 Author Share Posted October 2, 2008 A time-out occurred while communicating with the server. Account: 'Fun', Server: 'mail.bigpond.com', Protocol: SMTP, Port: 25, Secure(SSL): No, Error Number: A time-out occurred while communicating with the server. Account: 'Fun', Server: 'mail.bigpond.com', Protocol: SMTP, Port: 25, Secure(SSL): No, Error Number: Quote Link to comment Share on other sites More sharing options...
smokingwheels Posted October 2, 2008 Author Share Posted October 2, 2008 Proper punctuation and grammer would go a long way to clarifying whatever was posted above. Please read the rules and try to clean up the post so we can all figure out what you're asking: http://forums.hybridz.org/announcement.php?f=76&announcementid=2 A time-out occurred while communicating with the server. Account: 'Fun', Server: 'mail.bigpond.com', Protocol: SMTP, Port: 25, Secure(SSL): No, Error Number: Quote Link to comment Share on other sites More sharing options...
Careless Posted October 8, 2008 Share Posted October 8, 2008 it seems like someone who posts these weird links for people to click on is trying to get the localhost's smtp mail server to send out spam mail using hybridz's hosting package as an outlet. I would watch this guy. His links probably contain phishing scripts. Quote Link to comment Share on other sites More sharing options...
jerryb Posted October 8, 2008 Share Posted October 8, 2008 Or perhaps just a it seems like someone who posts these weird links for people to click on is trying to get the localhost's smtp mail server to send out spam mail using hybridz's hosting package as an outlet. I would watch this guy. His links probably contain phishing scripts. Quote Link to comment Share on other sites More sharing options...
smokingwheels Posted April 15, 2009 Author Share Posted April 15, 2009 Ive been building a web site so you can possibly understand what Im trying to do and have done over the last 9 years http://ampair.tripod.com I hope the blog page explanes a few things for the graphs I still have a bit to do there but all have titles Quote Link to comment Share on other sites More sharing options...
