PhaTTy Posted June 9, 2005 Share Posted June 9, 2005 OK.. I have looked over several threads dealing with these issues and need some guidance. What I have is an '83 N/A 280ZX. I am having a turbo engine built that will put me up around 400hp, and am having a second engine built that should be around 550hp (we hope). I need some help on what I can do with the clutch, transmission, driveshaft, rearend, axles, etc.. to beef it up to handle the extra horsepower and torque. My ideas so far to throw out there: Clutch: ACT 4-puck or 6-puck Transmission: T-5 or T-56 beefed up by G-Force or 5speeds type kit Driveshaft: Custom made? Differential: Open to ideas. Probably R200 or R230. Axles: custom billet 4340 280ZXT stub axles and billet companion flanges possibly made by Ross C. Suspension: Front/Rear Coilovers by Ross C. maybe Open to your thoughts and ideas.. Post away! Aaron Quote Link to comment Share on other sites More sharing options...
2126 Posted June 9, 2005 Share Posted June 9, 2005 Where are you heading with this project, drag racing? Quote Link to comment Share on other sites More sharing options...
PhaTTy Posted June 9, 2005 Author Share Posted June 9, 2005 Mainly a daily driver with plans to take it to the strip or track on the weekends. Quote Link to comment Share on other sites More sharing options...
2126 Posted June 9, 2005 Share Posted June 9, 2005 As a daily driver, the puck type clutches are pretty grabby...no conducive to normal street driving. Other than that, I'd say you should expect some broken parts now and then, especially if you drag race it. As you likely know, setting up a drag car vs a road course car vs an autocross car are three completely different animals. Keep us posted on your progress. Quote Link to comment Share on other sites More sharing options...
PhaTTy Posted June 9, 2005 Author Share Posted June 9, 2005 Is there a clutch type that would work well for both street and the occassional drag (I might take it to the strip 4 times a year just to have fun) ? I want something that will work well on the street since it will be driven almost daily, but I do not want to keep replacing parts. Thanks for the input so far.. Keep em coming! Quote Link to comment Share on other sites More sharing options...
510six Posted June 10, 2005 Share Posted June 10, 2005 "Is there a clutch type that would work well for both street and the occassional drag ". There sure is, but it`s not cheap http://pg.photos.yahoo.com/ph/sss510six/detail?.dir=15c7&.dnm=55c7.jpg&.src=ph http://www.10000rpm.com/ Quote Link to comment Share on other sites More sharing options...
HeatRaveR Posted June 10, 2005 Share Posted June 10, 2005 While we're on the subject, are there any other options for a lighter aftermarket flywheel for a 280ZX Turbo other than Fidanza? Quote Link to comment Share on other sites More sharing options...
260DET Posted June 10, 2005 Share Posted June 10, 2005 Go for a twin plate clutch, a bit of expense now saves a lot of effing around later, nice to drive in traffic, effective on the track. R200 clutch type diff (KAAZ?) or ATB (Quaife?) type should be ok, unless you are going to side slip it. The stock CV half shafts should be OK, unless, see above. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted June 12, 2005 Share Posted June 12, 2005 OK.. I have looked over several threads dealing with these issues and need some guidance. What I have is an '83 N/A 280ZX. I am having a turbo engine built that will put me up around 400hp' date=' and am having a second engine built that should be around 550hp (we hope). I need some help on what I can do with the clutch, transmission, driveshaft, rearend, axles, etc.. to beef it up to handle the extra horsepower and torque. My ideas so far to throw out there: Clutch: ACT 4-puck or 6-puck Transmission: T-5 or T-56 beefed up by G-Force or 5speeds type kit Driveshaft: Custom made? Differential: Open to ideas. Probably R200 or R230. Axles: custom billet 4340 280ZXT stub axles and billet companion flanges possibly made by Ross C. Suspension: Front/Rear Coilovers by Ross C. maybe Open to your thoughts and ideas.. Post away! Aaron[/quote'] Thats alot of stuff. I guess really the first question should be whats the budget and what kind of time frame are you on? Quote Link to comment Share on other sites More sharing options...
PhaTTy Posted June 12, 2005 Author Share Posted June 12, 2005 Budget for the drivetrain can probably be anywhere under $3000 for everything. Budget is not really an issue actually. As far as the timeframe. It will be a work in progress and I would like to see the 2nd higher horsepower (550hp we hope) in the engine with the drivetrain complete within 6 months or so. Quote Link to comment Share on other sites More sharing options...
TimZ Posted June 13, 2005 Share Posted June 13, 2005 Budget for the drivetrain can probably be anywhere under $3000 for everything. Budget is not really an issue actually. I must be reading that wrong - you don't really expect to do all that for under $3000, do you? The trans and clutch will most likely chew that up all by themselves, assuming you do all the fab by yourself. Quote Link to comment Share on other sites More sharing options...
PhaTTy Posted June 13, 2005 Author Share Posted June 13, 2005 Well.. I forgot to take the tranny into effect. The tranny most likely whether I go with a T-5 , T-56, or TKO2 will probably be about $3000 by itself LOL.. Clutch and flywheel should be around $900 on the high end. So altogether I will probably be looking at closer to $5000-$6000, which considering still isn't that big of a deal for what I will have when I am done. I just need a lot of suggestions and help deciding what to go into this monster. Thanks so far, Aaron Quote Link to comment Share on other sites More sharing options...
EZ-E Posted June 13, 2005 Share Posted June 13, 2005 One thing you forgot to mention is the driveshaft upgrade. I blew out my ujoints on my driveshaft, with only app. 275 horses to the wheels. The ujoints in the shaft are extremely small and will snap like a twig pretty easily. Quote Link to comment Share on other sites More sharing options...
PhaTTy Posted June 13, 2005 Author Share Posted June 13, 2005 Ooo yes. I planned to have a custom driveshaft made with much larger ujoints. I had a feeling the stock one wouldn't handle much at all. Thanks for the input though! Quote Link to comment Share on other sites More sharing options...
