Spherical Bearings in Control Arms
Wondering what is a sure and simple way to modify the front lower control arms inners to fit spherical bearings (Heim joints), not rod ends.
We were thinking of removing the existing tubular locater welded into the arm and replacing it with a fixed bush into which the bearing could be pressed. But perhaps the bearing should be positively located in the arm by a shoulder on one side and a circlip on the other.
So, who has done what and how did it turn out?
260DET, Are you talking about installing the spherical bearing into the existing cavity the stock bushings are in. I don't see a reason why you couldn't! I think the only issue you may run into is the sizing of the spherical bearing.....both OD and ID. And centering and securing the new bearing in the cavity. With this mod, you could also incorperate adjustable TC rods so you can adjust your caster. But you are probably planning to do that already!
What we have decided to do is to machine the housing out but only partway through the eye of the arm. The spherical (monoball) bearing will then be pressed in to sit against the shoulder created as above. It will be followed by a ring which will be tack welded to the arm to retain the bearing.
Will try and do a pic in due course.
