grumpyvette Posted July 13, 2005 Share Posted July 13, 2005 now I know you did not really ask, but you might want to look at this, its a rough idea still needing careful parts matching checks, before finalizing , its for a serious race only application, and at this point the combo needs tweaking, if anyone can post a picture of the DD DYNO power curve Id appreciate it as I can,t POST that PICTURE Corvette Dream engine, the ideas to get 700hp before the giggle gas injection,AND not to exceed 6000rpm, maximizing power from 3000rpm-6000rpm is the concern, I don,t want to change the bore/stroke or cylinder heads feel free to point out potential problems its still a rought draft idea at this point , its similar to other engines Ive built but with several new part designs and yeah its only going to see 115 octane not pump gas TALL DECK 4.5 bore Block #083111 http://www.worldcastings.com/docs/05_cat_pg7.pdf heads #020750-4 …….345cc http://www.worldcastings.com/docs/05_cat_pg23.pdf intake single plane dominator style http://www.worldcastings.com/docs/05_cat_pg27.pdf crank 4.375 stroke http://www.dougherbert.com/chevy-4340-forged-profiled-cranks-p-12960.html?cPath=1_359 solid roller cam http://www.dougherbert.com/8620-billet-roller-lifter-p-9820.html?cPath=83_84_87 roller lifters http://www.dougherbert.com/catalog/product_info.php?cPath=83_93&products_id=10117 rockers http://www.dougherbert.com/catalog/product_info.php?cPath=83_284&products_id=12702 pistons http://www.kb-silvolite.com/forged.php?action=details&P_id=399 RODS/ 6.8†eagle http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1240&prmenbr=361 dominator carb, 1150cfm http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=401189&prmenbr=361 500hp nitrous direct port injection http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3771&prmenbr=361 oil pan http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1756&prmenbr=361 yeah, its a 14:1 cpr 555 bbc, yeah the pistons are .058 out above deck ,unless machined, if the decks at minimum, they will be custom fitted or replaced with custom made Quote Link to comment Share on other sites More sharing options...
strotter Posted July 13, 2005 Share Posted July 13, 2005 Grumpy!!! A CA ... A CA ... A CARB? Man, you're the one that inspired me to get into mpfi! Your word at thirdgen diy-prom is scripture! Heck, it is here, too! Room spinning - world turned upside down - must - hold - on... Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted July 13, 2005 Author Share Posted July 13, 2005 DON,T PANIC Ive got the COMPLETE MPFI setup ready to install, the carbs only listed to make it easy to dyno Quote Link to comment Share on other sites More sharing options...
pparaska Posted July 29, 2005 Share Posted July 29, 2005 I only wish I could give YOU advice on matching components! I'd be happy to run a DD2000 run for you. But I can't find flow #s for those heads ANYWHERE. Any ideas? Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted July 29, 2005 Author Share Posted July 29, 2005 you can use these specs from the AFR 345cc head the differance is minor and the new heads are supposed to slighly exceed those specs Quote Link to comment Share on other sites More sharing options...
pparaska Posted July 29, 2005 Share Posted July 29, 2005 I had trouble uploading pics tonight too. Not sure what's up. Anyway, I used your data, the AFR flow numbers, the Chet Herbert cam specs (seat timing, lift, LSA), 1150cfm @1.5Hg carb, "Large stepped tube race headers", "single plane" manifold. One run without Juice, one with 20lbm/min of N20 (since they only went up to 400 hp shot in the pull down which gives 16lb/min). Here they are: No N20: http://alteredz.com/data/grumpyvette555BBC_nojuice.png 20lbm/min (500hp shot) N20: http://alteredz.com/data/grumpyvette555BBC_20PPMNOS.png Tabular form: rpm hp ft-lbs 2000 228 599 2500 320 672 3000 405 709 3500 489 733 4000 577 757 4500 664 775 5000 734 770[b] 5500 780 745 6000 781 683[/b] 6500 764 617 7000 720 540 7500 666 466 8000 601 394 HP Peak is somewhere between 5500 and 6000 rpm. Just what you wanted! N20: rpm hp ft-lbs 2000 743 1951 2500 827 1738 3000 907 1587 3500 990 1486 4000 1078 1415 4500 1161 1354 5000 1227 1289 5500 1273 1216 [b]6000 1279 1119[/b] 6500 1266 1023 7000 1227 920 7500 1177 824 8000 1111 729 HP peak looks to be right around 6000 rpm! What a beast! Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 29, 2005 Share Posted July 29, 2005 Here ya go Pete/Grumpy. (Pete, it has to be .jpg. .Png won't upload) Quote Link to comment Share on other sites More sharing options...
Michael Posted August 4, 2005 Share Posted August 4, 2005 Questions for you, Grumpy – 1. To what extent should we trust those DD2000 numbers? 1951 ft-lbs at 2000 rpm??? Running a “junior version†of your engine (461, Brodix Race-Rite oval-port heads, 0.640†mechanical roller, dual-plane, 750 cfm, also 6000-rpm limit, but no nitrous) on DD2000 ad nauseam I also get remarkably good numbers – like 596 ft-lb at 4000 rpm, 559 hp at 5000 rpm. In my application, by the way, DD2000 predicts a drop of almost 150 ft-lb in going from 5000 to 5500 rpm. 2. Are those lifters similar to the Isky Red-zones? 3. I understand the quoted bore limitations with that block, but why not a larger stroke? 4. Any nitrous-specific considerations for the cam, such as greater intake duration than one might have chosen otherwise? 5. Would the deck have to be O-ringed? 6. What sort of valve spring pressures would be needed? Would you need a shaft rocker system? 7. At this power level, are there any symmetric-port heads available with “smallâ€-enough (as opposed to pro-stock) intake ports? Quote Link to comment Share on other sites More sharing options...
Michael Posted August 4, 2005 Share Posted August 4, 2005 Oops, disregard question #2 - they ARE the same lifters. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted August 4, 2005 Author Share Posted August 4, 2005 Quote Questions for you' date=' Grumpy – 1. To what extent should we trust those DD2000 numbers? [b']the peak numbers ant the rpm peaks suggested are normally close to correct PROVIDED ALL the DATA is correct but the tq figures below about 4000rpm are usually predicted well higher than the true dyno results[/b] 1951 ft-lbs at 2000 rpm??? most likely BS, but keep in mind you don,t inject nitrous below about 3000rpm and usually have a swithch that tuns it off at 6200rpm if the rev limiters set to 6100rpm Running a “junior version†of your engine (461, Brodix Race-Rite oval-port heads, 0.640†mechanical roller, dual-plane, 750 cfm, also 6000-rpm limit, but no nitrous) on DD2000 ad nauseam I also get remarkably good numbers – like 596 ft-lb at 4000 rpm, 559 hp at 5000 rpm. again most likely optomistic In my application, by the way, DD2000 predicts a drop of almost 150 ft-lb in going from 5000 to 5500 rpm. id suspect thats B.S. also, keep in mind that DD-2000 its a useful tool but not a serious representation of the whole power curve, Id suspect that only the PEAK numbers are close 3. I understand the quoted bore limitations with that block, but why not a larger stroke? its got to do with piston speed and stress on the engine parts, a 4.375 stroke , hits 4000 fpm in piston speed at about 5500rpm, 4500fpm is at about 6200rpm, you generally run into long term problems with stress, bearing wear,ETC once you exceed 4000fpm , but once you exceed 4500fpm your looking at a serious reduction in expected engine life, thats why G.M. gave thier 572 a 4.37" stroke vs the more comon 4.5" used in building a 572 displacement , look http://www.sallee-chevrolet.com/ChevyBigBlockV8s/572.html 4. Any nitrous-specific considerations for the cam, such as greater intake duration than one might have chosen otherwise? the cam selected is a compromise designed MOSTLY for NON-nitrous results, IF Id sellected a NITROUS cam it would have a large LSA and more exhaust durration plus an earlier exhaust valve opening point, keep in mind IM not building this as a all out race engine, its a high performance engine that might see some extremely limited street use. 5. Would the deck have to be O-ringed? NO, but then Id use soft copper head gaskets without the (O) ring which has proven to work just fine in other nitrous BBCs Ive built 6. What sort of valve spring pressures would be needed? Would you need a shaft rocker system? I detest shaft rockers due onlyto the increased costs and avoid them if the application does NOT REQUIRE thier use,, Id use THE MINIMUM spring pressure with the max clearance I think I could expect to run correctly, in this case Id sellect something in the 225 ftlbs closed to 600ftlbs open range 7. At this power level, are there any symmetric-port heads available with “smallâ€-enough (as opposed to pro-stock) intake ports? yes, but the costs go up a great deal,I don,t think the results are worth the cost differance if your not racing as a bussiness vs a serious hobby Quote Link to comment Share on other sites More sharing options...
Michael Posted August 10, 2005 Share Posted August 10, 2005 Understood about the piston-speed constraint. But what do you think of the following train of thought: going from a 4.375 to a 4.5 stroke (for example) is only about a 2.9% increase in piston speed and displacement. If the engine maintains the same peak volumetric efficiency, peak torque should rise by the same 2.9%. And if the rpm for peak V.E. goes down by 2.9%, peak hp stays constant. However, for the same compression ratio the 0.125†extra stroke buys a 2.5cc reduction in piston dome (if I recall correctly the specs of your heads) to get the same compression as with the smaller stroke– and conceivably, with the smaller dome the result is a slightly lighter piston with slightly better flame-front propagation, hence better combustion efficiency. So, because peak hp hasn’t budged, the benefits in a racing engine are questionable – but in a street engine, especially in a relatively heavy car like the Corvette, the trade of extra stroke at the expense of reduction in peak rpm might make sense. Do you have a broad choice of gears for that Dana 44 (or whatever differential the Corvette uses)? BTW I’ve heard elsewhere that copper head gaskets are tough to seal for an aluminum head/cast-iron block application (yes, I know that your application is an aluminum block). This seems counterintuitive, and contradicts some discussions on this site – including, if I recall correctly, your posts. What’s your opinion on copper head gaskets in the 0.040â€-thickness range? Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted August 10, 2005 Author Share Posted August 10, 2005 Quote Understood about the piston-speed constraint. ...............the trade of extra stroke at the expense of reduction in peak rpm might make sense. since the engine uses FLAT TOP pistons and 80cc cmbustion chamber heads with 14:1 cpr theres no gains to be had removing a non-existant piston dome' date='your correct about the increased stroke and resulting displacement increase ,in that it would more than likely aid rather than hinder the power production, even at the expence of a small loss in mechanical efficiency. GOOD POINT, thats why I posted,this Ill consider it and do the math research necessary in detail.........btw theres other factors like bearing oil film surface speeds and internal load/drag, that also tend to cause potential problems once that 4500fpm is reached,the stress is not linier its on a geometric progression as the stroke increases . a 3% stroke increase could easily result in a 8%-12% stress increase[/b'] Do you have a broad choice of gears for that Dana 44 (or whatever differential the Corvette uses)? youve GOT TO BE kidding about useing a corvettes dana 44,INDEPENDENT REAR SUSPENSION on an engine like this will twist that flimsy junk up on the first launch, Im probably installing a solid axle 4 link dana 60, but once I do the math I may be forced to install a 11.5' truck DANA rear like the pro mods use BTW I’ve heard elsewhere that copper head gaskets are tough to seal for an aluminum head/cast-iron block application (yes, I know that your application is an aluminum block). This seems counterintuitive, and contradicts some discussions on this site – including, if I recall correctly, your posts. What’s your opinion on copper head gaskets in the 0.040â€-thickness range? Ive never yet had the smallest problem useing solid copper head gaskets, I am useing them currently on several iron engines with aluminum heads including my corvette 383 which sees a 200hp nitrous boost ocationally, I guess I find out thru trial/error if an all aluminum combo reacts similarly Quote Link to comment Share on other sites More sharing options...
