Guest JAMIE T Posted July 14, 2005 Share Posted July 14, 2005 I'm trying to find all relavent information to rebuild (sorta) my RB26. I'm looking for the english FSM for an R32 or R33 Skyline. Someone has it. It's on the racebread forum but I can't seem to download it. It locked my computer up once, and just stayed blank the second time. I'm not super computer savy, so it might be my fault. But if anyone has relavent pages(engine, etc...) I'd appreciate it. Thanks Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted July 14, 2005 Share Posted July 14, 2005 Jamie, you should know better. Search or look in the stickies for links. Just kidding, here ya go... http://www.japtastic.co.uk/ http://www.japtastic.co.uk/R32%20Manuals/gtr_32_service_manual.pdf [Right Cligk Save As... for R32] http://www.japtastic.co.uk/R33%20Manuals/ [bunch of different info for R33, service manual is 148MB so don't open it directly] Does this help? Don't forget that everything is in metric or Newton Meters. Us yanks never got it so nothing is in ft/lbs. Quote Link to comment Share on other sites More sharing options...
stony Posted July 14, 2005 Share Posted July 14, 2005 i believe i have one on the yahoo forum in one of the folders. If you need an entire manual i can email it. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted July 14, 2005 Share Posted July 14, 2005 Uh, no need to email it, just look in the links I posted, it's all there! Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted July 14, 2005 Share Posted July 14, 2005 Thanks for the links. The same links on Racebread did not work for me. Like I said in the first post, maybe it's my PC at home or just me being a fumbling idiot(not likely). But, I did it just now on my work PC using your links and it seems to be loading fine. Will probably take an hour but hey... Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted July 14, 2005 Share Posted July 14, 2005 OK, that didn't work. It told me the file was damaged and could not be repaired. That was after loading 28MB of it out of 148MB's. Stony, I really only need the vital engine information. If you don't mind emailing that to me. I could not locate it on the yahoo group. Thanks. Quote Link to comment Share on other sites More sharing options...
Zhadman Posted July 14, 2005 Share Posted July 14, 2005 Jamie, Here's a direct link to the PDF. Once it opens you can save it (I just tried it to verify that it works). http://www.hkskylineclub.com/images/Techsource/gtr_32_service_manual.pdf OK, that didn't work. It told me the file was damaged and could not be repaired. That was after loading 28MB... I was able to download that one ok... perhaps its a computer issue. Quote Link to comment Share on other sites More sharing options...
Stealth-Z Posted July 14, 2005 Share Posted July 14, 2005 I had the same problem with the file being bad. After updating Acrobat Reader it solved the problem. Quote Link to comment Share on other sites More sharing options...
stony Posted July 14, 2005 Share Posted July 14, 2005 sent......Its 23 meg so hope you dont have any limits on your email. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted July 14, 2005 Share Posted July 14, 2005 Thanks Stony, I haven't seen it yet. My PC at work has the latest Adobe reader and I down loaded the latest version on my home unit last night, but still nothing from the japtastik sight. I even have broadband at home and DSL at work. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted July 14, 2005 Share Posted July 14, 2005 A lot of computers have problems with opening PDFs. So you're not the only one. Quote Link to comment Share on other sites More sharing options...
Sean 83ZXT Posted July 14, 2005 Share Posted July 14, 2005 Generally it's a corrupt temp file. If you go to Start > Run and type %temp% and hit enter your temp folder will open. As long as all your of applications are closed you should be able to delete everything in this folder and then you can try opening the file again. Quote Link to comment Share on other sites More sharing options...
Zhadman Posted July 14, 2005 Share Posted July 14, 2005 Has anyone (other than me) verified the link I posted? I'll delete it if there are problems with it. It's a bit of a download... but it came out ok for me. Quote Link to comment Share on other sites More sharing options...
