loud pop now only 10 psi of boost?? need help
I've got a problem. I've just installed a stage III turbine wheel in my t3/t4 turbo to solve my topend chock up. Well it was boosting fine 19-20psi and then just like that a loud pop and only like 10psi max. I don't belive that I have a leak but I'm not 100% for sure but it really sux. I do maintain a perfect idle with 19.5 in of vacume.
tbs
  Drax240z said:
Pressurize your entire intake system at 10psi with a regulator and an airhose and do soap and water leak checks. You'll be amazed what you can find that way that you won't find at idle.
Thats a good idea. If it's a air leak not letting your car go over 10 psi then it should be pretty easy to spot.
