DaleMX Posted September 23, 2005 Share Posted September 23, 2005 How did you guy's seal the headers to the block and how did you seal the collector to the flange? I used the stock steel exhaust gaskets between the headers and the heads, but used a regular exhaust gasket on the collector flange. The collector flange leaks really bad. The Sanderson instructions for the header to head part use black permatex, but no instructions were included for the collector. I called JTR and they said it was a gasketless design but after I got off the phone I realized he was talking about the header to head. OK, so what did you guys do? Quote Link to comment Share on other sites More sharing options...
MikeJTR Posted September 23, 2005 Share Posted September 23, 2005 I believe the best gasket to use between the cylinder head and the header is the stock LS1 tri-metal gasket (three layers of metal). For the collector, the copper gaskets are the best. Sanderson carries these gaskets, as well as Summit Racing. It also helps to use a 3/8" thick flange on the head pipe. Quote Link to comment Share on other sites More sharing options...
qwik240z Posted September 24, 2005 Share Posted September 24, 2005 Quote I believe the best gasket to use between the cylinder head and the header is the stock LS1 tri-metal gasket (three layers of metal).For the collector' date=' the copper gaskets are the best. Sanderson carries these gaskets, as well as Summit Racing. It also helps to use a 3/8" thick flange on the head pipe.[/quote'] Yep. This is what is now on my car after having the collector gasket blow out. No more problems. Quote Link to comment Share on other sites More sharing options...
DaleMX Posted September 25, 2005 Author Share Posted September 25, 2005 Thanks guy's. The stock header gasket is working fine just like yours, but I'm changing over to the copper gaskets for the collector right away and ditching the disposable ones that last an hour. I dont want to have to remove the bolts off of that thing again any time soon. They are hard to reach. Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted September 25, 2005 Share Posted September 25, 2005 good to know guys, since i'll be there soon enuf. love hybridz and the way i can learn from others. i can honestly say i'd never have tackled this swap without you all! david Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted January 23, 2006 Share Posted January 23, 2006 dale & dave, did you both use the black permatex & factory stainless steel sandwich gasket when mounting the sanderson/jtr headers to the head? still need to source the copper gaskets for the collectors. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted January 23, 2006 Share Posted January 23, 2006 Just a word on those GM 3 layer metal gaskets... I've had one pair off FOUR times and they always seal back up. I'm convinced this 3 layer metal gasket is the best on the market... Hard to believe GM made it! Mike Quote Link to comment Share on other sites More sharing options...
DaleMX Posted January 23, 2006 Author Share Posted January 23, 2006 1 tuff z said: dale & dave, did you both use the black permatex & factory stainless steel sandwich gasket when mounting the sanderson/jtr headers to the head? still need to source the copper gaskets for the collectors. Nope, just use the stock gasket (forget about the permatex). Just like Mike said, the gasket can be used over and over again. The copper collector gaskets are available from Jegs. Quote Link to comment Share on other sites More sharing options...
