Parts interchange CA SMOG
datz280
I have a broken Thermal vacuum valve from my 1977 280. Calling the local auto parts and no one caries or can order the part. Does anyone know of a different year Nissan that has a tvv that will work?
I need this part to get vacuum to the BPT and EGR to pass smog in California. I was thinking that if I can not find the valve would it be possible to T off of another vacuum line to get vacuum to the EGR. I only need to get the EGR working to pass smog and I do not think a smog station will look to see where the EGR is getting vacuum from, only that it is.
Thanks,
Mike
EDIT:
It appears that the Thermo Vacuum Valve is also called a Ported Vacuum Switch. Napa auto parts has two different styles for the 77. This is the one I think I need. http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=CRB&PartNumber=229056&Description=Ported+Vacuum+Switch its temp range is 112-118.
  • 2 years later...
