Dog gamn car............
Bernardd
EEH, it's nothing. Take a look at JeffP's cylinders from when we took the head off last year! And that was still "nothing" it's going back together right now, cylinders not touched.
I might take a look to see if the PISTON LAND is damaged causing the marking---but the cylinder wall is fine! My bet is broken land, or ring bit causing the irregular wear pattern.
JeffP's was on the opposite side, on the piston thrust face, far wider, and a result of piston clearances at....uh....245+ Degrees Farenheit! If it didn't seize then Jeff, it aint going to! LOL
My concern would be with the piston itself as that should not have a wear pattern there!
I'll mic to see if the cylinder is out of round. There is nothing I can feel there, it just looks polished, wouldn't a ringland scratch it more than polish it? The motor ran fine, had no knock, used about a liter of oil per 1000km's which is what it's pretty much alway been since I've owned the car. Hmmmmmmmmmm, I'm seeing a v8 in my future.
