Calling Grumpy and all others
Grumpyvette
I am using a Muncie M20 with a 84-88 corvette bell housing. I bought a new 85 corvette slave cylinder and got it on and working but the little datsun master just doesnt have enough. Also the slave extends into the oil filter. The one I have is a generic for a gm 350. Is there a shorter profile oil filter for a corvette?
JTR recommends a tilton master and for the corvette slave it says to buy it in a 13/16" bore.
Could you confirm this is the one
http://www.tiltonracing.com/content.php?page=list2&id=22&m=b
Also does anyone have any input for sources or sizes before I order it as I have a garage full ofparts I have bought thatare not quite the right fit.
Thanks
That be the one...
As to the slave, you may have to shorten the rod a bit. I'd run the best filter you can, and the higher the volume, the better... Shorten the slave rod if possible.
If you have to run a smaller depth filter, go with one from (I think) an early 80s 350 caprice.
Mike
Shortening the rod is on the other end. It is the closed end of the slave that encroaches oon the area of the oil filter. I have a relocation kit but have not installed it yet as I havent finalized the exhaust. Just wondering if the corvette oil filter was shorter in stature to make room for the oil filter.
sorry I did not see this earlier, my computer crashed for 25 hrs, but it appears the other guys helped out
http://www.cantonracingproducts.com/adapters/remote_filter.html
http://www.permacool.com/Catalog/Cat_page31.html
http://www.perma-cool.com/Catalog/Cat_page30.html
http://www.pegasusautoracing.com/group.asp?GroupID=OILFILTHEAD
you also may want to keep in mind that theres several DOZEN differant remote oil filter adapters available,that allow both more clearance and better filtering of the oil, dual remote oil filters,even oil coolers with filters
