big-phil Posted December 7, 2005 Share Posted December 7, 2005 I put the timing light on #1 plug wire, unplug the throttle posittion sensor, and put a jumper wire in the plug, start the car, shine the light and it shows the timing mark. But when I move the dizzy one way or the other, the timing mark does not move at all. It just stays in the same place. Read my profile below for the motor specs. I've timed many vehicals before but never a turbo. Its driving me crazy, the mark just does not move!?!? It reads off the scale right now. Quote Link to comment Share on other sites More sharing options...
Phyxius Posted December 8, 2005 Share Posted December 8, 2005 are you using the setup from an '81 or '82-'83? The '81 had a CAS and the dizzy was empty of electronics. Timing was adjusted by playing with the cas... Quote Link to comment Share on other sites More sharing options...
big-phil Posted December 8, 2005 Author Share Posted December 8, 2005 83 dizzy with cas inside. Quote Link to comment Share on other sites More sharing options...
Warren Posted December 8, 2005 Share Posted December 8, 2005 Refer to the FSM, EF&EC 61, 67 & 68 (82 model FSM that is). Timing is controlled by the ECU based on inputs from various sensors. Adjustment prodecure on EF&EC 68. Give me your email address and I'll send you the section if you need it. Warren Quote Link to comment Share on other sites More sharing options...
datsunan Posted December 14, 2005 Share Posted December 14, 2005 I have an 83 dizzy and can change my timing at the dizzy as he was describing. Warren can I get that procedure from the fsm? pdierolf@sbcglobal.net. I have been having problems with a missfire into my intake that may be timing related. Thanks Paul. Quote Link to comment Share on other sites More sharing options...
