Boy from Oz Posted December 19, 2005 Share Posted December 19, 2005 I am starting on a 240Z - 250 GTO project and would like to have the exhausts exiting on either side, at the rear. To do this I am considering removing the spare tyre well. I have not had a flat tyre for years (famous last words) and figure that I could probably get away with a can of pressure pack puncture repair stuff it I did. I could just throw a spare in for the yearly registration inspections. Any thoughts? I could also fit a custom made alumium fuel tank. Quote Link to comment Share on other sites More sharing options...
Guest Grenade300 Posted December 19, 2005 Share Posted December 19, 2005 you're having the same delima as me, I want duel exhaust, but I on the other hand I am a magnet for flat tires. So, my thought is to cut out the spate tire well and move it over about 3 to 4 inches over, then you could move the fuel tank over with it. As with anything, that seems easy in theory but may involve more work than I thought. edit: this would leave enough room for duel exhaust, however you would need to use smaller diameter mufflers. Quote Link to comment Share on other sites More sharing options...
drunkenmaster Posted December 19, 2005 Share Posted December 19, 2005 A couple of local cars do it and run a custom tank, so its not that outrageous. That tyre foam makes a mess on your rim though. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted December 19, 2005 Share Posted December 19, 2005 You just remove the spare tire well out and just put the spare in the trunk (above the panel). It should have straps. A custom/racing gas tank sound good, but if I were to install one I would have to as low as possible to keep the center of gravity down, maybe put a shield on there to protect the lines. Just a suggestion. Quote Link to comment Share on other sites More sharing options...
Wagz Posted December 19, 2005 Share Posted December 19, 2005 Works for me. Here's some pics from my Velo Rossa project: Quote Link to comment Share on other sites More sharing options...
Bartman Posted December 19, 2005 Share Posted December 19, 2005 Instead of going with a fuel cell, I used a nylon tank from a 2001 Trans Am. Here's a link to a thread about it. http://forums.hybridz.org/showthread.php?t=101232 Quote Link to comment Share on other sites More sharing options...
buZy Posted December 19, 2005 Share Posted December 19, 2005 I did the same thing. Dual mufflers. 12 gal fuel cell. Quote Link to comment Share on other sites More sharing options...
YoungZOwner Posted December 19, 2005 Share Posted December 19, 2005 I am doing along the same idea, i cut out the spare tire, put new floor across, so that i can run dual exhaust out both sides. i put in a new gas tank out of a 69 mustang actually bc it has a flat top and the center top mount filler, bc i am always running a center fill gas cap. I have to do a lot more to finish it but when i get my rear panel done i can take some pictures. Need to update you guys anyways. Quote Link to comment Share on other sites More sharing options...
DaleMX Posted December 20, 2005 Share Posted December 20, 2005 Personally, I think the TransAM tank is a great idea. After I saw Bart's original post I found a 2001 tank on Ebay with the pump for 75 bucks. Look's like a great fit with minimal effort. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted December 20, 2005 Share Posted December 20, 2005 how is the fuel cell strapped in on the bottom? like hows the "floor" done up.. very nice mike Quote Link to comment Share on other sites More sharing options...
