3.2L stroker kit
Oleh
Hmm, crank offset ground to give an 85mm stroke and 138mm rods to give a rod/stroke of 1.62, slightly better than standard 3.1 stroker build 133/83 ~1.6
* LD28 reforming 3 ? 2 liter high rotary crank * aerodynamic volume displacement/3 ? 171 cc
(Crankpin offset grinding/ST85 mm pin diameter 48 f ? spill ? Taft ? bending correction ? journal lapping ? stroke 85 mm)
* Piston kits for 89 f turtle possession race/lace
* 138 mm/590 g lightweight connecting rod
(Full flow ? lightweight pressing in connecting rod volt/bolt)
* Metal set for race/lace * M12/1 ? 25P strengthening crank cap volt/bolt
(Parent metal NISMO+5/100 m ? child metal TRD+4/100 m metal clearance adjustment it is completed)
(Â¥30' date='000 of classified by main point volt/bolt rise processed generation)
Usually when the L type engine is tuned, bore rise and stroke rise are done and as the most general method power rise is assured by increasing the aerodynamic volume displacement. But when it keeps seeking ? further aerodynamic volume displacement rise, with bore rise with the piston of ? 90 f or more rigidity decreases substantially with the restriction of ? bore pitch and when the full counter crank of the ? and marketing is used, with just the component of ? cylinder block the ? considerably becomes large amount ones. Then without decreasing the durability of ? L28 cylinder block in order enlargement of the ? total cubic displacement and to assure power rise, LD28 which has the ? result/only crankpin side 48 to do offset grinding with f and to designate ? crank stroke as 85 mm and the total cubic displacement to become 3 ? 171 cc with ? 89 f piston use, the ? also cost reductioncouldbe compatible the high rotary crank. Increase of ? further torque and improvement of the pickup were made possible with this long-stroke conversion.The processing this & the LD28 reforming 3 ? 2 liter highrotary crank & the ? spill ? Taft ? balance ? bending correction ? journal lapping etc. is administered and metal clearance of ? crankpin side at the time of ? off set grinding in 4/100 mm for the setting being completed ? metal adjustment becomes unnecessary and furthermore the vibration at the time of high time revolution of the ? crankshaft is reduced substantially. If agic LDR/3 ? 2 liters kit because ? crank ? piston ? ?? rod ? metal ? crank cap volt/bolt becomes the set part, ? prepare L28/N42 block, 3 ? 2 liter engines complete with only boring ? crank cap volt/bolt enlargement processing. Furthermore in doing cylinder/line boring processing it needs and degree of completion improves and ? 1 - 3rd gear/9 ? 000 rpm, 5 speeds/also 7 ? 500 rpm are possible
[/quote']
Cheers,
Rob
