turbo_fb Posted February 12, 2006 Share Posted February 12, 2006 Quote I think i've got it now. I did more searching on the exvit site' date=' and i'm prett sure its another overflow line. [img']http://i3.photobucket.com/albums/y98/hansonicochico/exvitsecret.jpg[/img] i traced where i think the line goes. Seems to me like he could have skipped the second tank there. Quote Link to comment Share on other sites More sharing options...
HakosukaJD Posted February 12, 2006 Share Posted February 12, 2006 I know its not the topic...but is that the stock brake booster? If not, what is it from? Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted February 13, 2006 Share Posted February 13, 2006 Quote This is the GT cooling setup you see on some of the race cars such as JUN and the Exvitermini stuff. Using a mill you plunge down to the water passage in the manifold between ports 1-2' date=' 3-4 and 5-6. I then welded a -8 male an fitting to the manifold. This will run to a reservoir that will also be a merge for the water returns for the turbo's. From there it will run back to the radiator. Basically, all the water leaves the head and runs to the front of the intake via the log on the bottom. To help expidite coolant flow from the head we supplement by adding additional outage points from the manifold. It would have probably looked a bit more clean on the bottom of the manifold, but might as well show it off. [img']http://www.speedshopthagard.com/pics/projects/RB26DETT/cooling1.jpg[/img] This is the coolant plenum I just fab'd. The 3x -8 AN connectors are fed from the intake manifold. The 2x -6 AN connectors are the coolant returns for the turbos. The single -12 AN connector on the bottom connects to the radiator. The coolant plenum runs as it did stock to the front of the manifold where I have fab'd a -16 AN male connector and also welded a -16 AN connector to the radiator. This will supplement the stock setup. The radiator has both a -12 and -16 bung for the inlet and another -16 for the outlet. Does anyone want to elaborate more on this mod? Specifically the mod to the ITB's. Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted February 13, 2006 Share Posted February 13, 2006 After going through thr RB manual a few times, to get more insite into this mod, I see that the intake has a water by-pass already. So why do this mod to begin with? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted February 13, 2006 Share Posted February 13, 2006 James is the one that really needs to explain the coolant passage flow, as I've already forgotton how I'm supose to plumb it.... Here are a couple pics showing how James "plunged" into the water jackets on the intake. The one pic thats blurry is the one showing that. I belive the mod makes it to where more water is passed thru these passages, and not have to go back thru the hot block, but hopefully James will explain the route the coolant takes... More pics here>> http://album.hybridz.org/showgallery.php?cat=566 Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted February 14, 2006 Share Posted February 14, 2006 J. Soileau RB26zcar said: James is the one that really needs to explain the coolant passage flow, as I've already forgotton how I'm supose to plumb it.... Joel, I don't know anything about helping cool the cylinder head. You told me you wanted heated seats and a coffee warmer Quote Link to comment Share on other sites More sharing options...
