Guest SouthGaZX Posted January 31, 2006 Share Posted January 31, 2006 ok.. i purchased a 77 280z with l28.. at first it wouldnt fire up..i drained the old RED gasoline (TOO much rust lol) and refilled with fresh well it still turned over... no start... i took the bolt out of the base of the distrib that keeps the cap from rotating too far one way or the other.. and turned the cap clockwise untill the slot is about 1/4 right of the bolt hole and it fired up.. doesnt stay running unless you keep on the throttle a little though... its like the base of the distrib needs to be turned 1/4-1/2 inch clockwise.. also i think its possible only 4 or 5 of my injectors are working.. because 4 or 5 plugs were soaked.. 1 or 2 were dry.. started raining a little.. and the car battery died so ill have to wait till tomorrow to check the injectors.. but what could be causing the distributor to be doing that? Quote Link to comment Share on other sites More sharing options...
AK-Z Posted January 31, 2006 Share Posted January 31, 2006 Check to see if the vacuum advance is stuck on the dizzy. Also check if the plug wires are damaged. And check to see if the advance adjustment plate is mounted properly. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted January 31, 2006 Share Posted January 31, 2006 What happened to the car before you purchased it? Someone try to fix it and give up maybe? Sounds like somebody put the distributor shaft in in the wrong position. To fix that you'll need to pull the oil pump, take the shaft out rotate it to the right position, and put it back in. Easiest way is to have a person on top while you're on the bottom moving the shaft. Set it so the rotor points a little advance of the #1 spark plug terminal and you should be good to go. If you have an aftermarket sway bar you'll have to loosen the bushings on the frame on both sides. I think you can squeeze the shaft out if you're running the stock swaybar. Quote Link to comment Share on other sites More sharing options...
Guest SouthGaZX Posted January 31, 2006 Share Posted January 31, 2006 thanks guys.. ill try and post a reply tomorrow.. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted January 31, 2006 Share Posted January 31, 2006 Just remember to set the crank to TDC and adjust from there. You have to remove the oil pump to adjust the shaft, Yous don't have to remove the shaft all the way. Quote Link to comment Share on other sites More sharing options...
datsunan Posted January 31, 2006 Share Posted January 31, 2006 Why bother screwing with the timing if you suspect your injectors are not firing. They may be clogged with rust. I would start with the obvious. Quote Link to comment Share on other sites More sharing options...
Guest SouthGaZX Posted February 1, 2006 Share Posted February 1, 2006 well like i said... the distrib cap has to be rotated 1/2 inch or more past where the slot stop is im still gonna check injecs first didnt say i wasnt just wanted to know what to do about the distrib... also does the original 77 z heads come with a temp sensor?? because i have a 83 280zx head on it.. with the temp sensor but i have no hookup.. so i dunno if the original 77 heads had the sensor or not? i know if that sensor goes bad it dumps alot of fuel in.. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted February 1, 2006 Share Posted February 1, 2006 It did but not sure if the ecu used it at all though. I think it was just hooded up to the temp gauge to tell when the engine was over heating. If it did and it wasn't hooked up then the engine would still run and be in "limp mode" the engine would still run. Quote Link to comment Share on other sites More sharing options...
