15x8 wheels that fit
Offsets are measured in MM not inches. A 1/2" offset would be a 12 MM offset no matter wich direction it is measured + or -. I would go with a 0 offset or you could have problems clearing the suspension. A +12 (1/2") offset would be a 5" back space which would be too much with the stock suspension, if you have coilovers you should be fine. I have 7" wheels with a -12 offset (they extend out the same amount as an 8" wheel with a 0 offset) and the stock fenders on my car with out rubbing issued on the front or the rear.
Guest alanq64
Hey J Taylor, what did you have to do to get the toyota wheels on the back of your z? Any mods or did the just bolt up? I have access to a complete set and wasn't sure if they would fit.
zguitar71:
I was approximating the amount of backspacing needed, and when I used to buy wheels for my musclecars, the offset was measured in inches and fractions thereof - I'm 52.
The JTR manual talking in terms of inches and fractions thereof when talking about offset and backspacing.
As this is a Hybrid site, we are used to dealing in both inches and millimeters - at least those with chevy and ford engines. Most of us know that a 13mm wrench is very close to .5" and can in fact be used on a .5" bolt or nut - try that with a 12mm and you're out of luck. An inch is 25.4mm, meaning that .5" is 12.7mm.
This would mean he would need ~a 13mm positive offset - if you are going to correct me, at least be correct.
You are correct in stating that coilovers will be needed if he doesn't want to flair, but then again, all of this info is available on a search....
No adapters on mine. Actully, it has conquest rotors/calipers in the back as well with some home made brackets. Don't ask....they were on the car when I bought it.
The wheels I am using are the 16x7's (+18 offset I believe). They fit great but I had to shave the fender lips to fit the drag radials on them though.
JT
