Somewhat bummed at 450RWHP, 500+rw torque
I am sure a lot of thought went into your nice repsonse but I have a couple of comments.
  Quote
I know there's hordes of people telling you to just "turn up the boost" ... but I'll be the first to disagree. The more you tun up the boost' date=' the less responsive your package is going to be.[/quote']
First I ever heard of that one and the opposite of what I and every turbo driver I know has experienced. Turning the boost up should not change the responsiveness of the engine, just add more HP at the new peak boost level.
  ModToad said:
The Gran National turbos are decently sized, but probably quite undersized for your application, and somewhat outdated.
Cannot disagree with the "outdated" statement. However, this V8 engine is 3.14L per bank/turbo and the GN engine is 3.8L. Unless he is looking to make well over 700hp, I am not sure this is a valid statement.
  ModToad said:
You may be under the surge line (each turbo is pushing a theoretic 4 psi, way outside of where it was balanced for)
I hope I am not misinterpreting what you are saying but he is running 8psi and I interpret this statement as saying 8psi = 4psi per turbo.
  • Replies 66
Well, then how much does bumpstick change the total HP output in a turbo engine. Say for example a sbc as is the case here. What cam you running silicone boy?
What would be the difference, say with a .480 lift 230 dur at .050 and 114LSA hydraulic turbo grind and say what I'm running solid roller .618/.630 244/250 @.050 and 114LSA, just curious??
It's been so long since I started the project that I can't remember off the top of my head what the cam is, but it's purpose was for a streetable, smooth idling normally aspirated stroker motor and not optimized for a turbo application. Lift was about .480 at .050. I agree that an extra 150 hp with a more aggressive cam is optimistic.
  Quote
Well' date=' then how much does bumpstick change the total HP output in a turbo engine. Say for example a sbc as is the case here. What cam you running silicone boy?
What would be the difference, say with a .480 lift 230 dur at .050 and 114LSA hydraulic turbo grind and say what I'm running solid roller .618/.630 244/250 @.050 and 114LSA, just curious??[/quote']
I found the cam specs. It's a Comp Cams Extreme Energy 270 hydraulic roller. Complete specs can be found here:
http://www.compcams.com/Technical/Search/CamDetails.asp?PartNumber=08-422-8
Again, more for streetability at lower RPM than all out turbo performance.
As for the choice of the Buick GN turbos, they can be found everywhere and I wanted to keep this a budget install. It didn't turn out that way and I ended up rebuilding the turbos anyway. I would have done better to purchase turbos that are more optimized to the application, but as our resident GN expert Scottie has indicated, they aren't bad either.
Doesn't look too bad to use as a turbo cam... maybe could use a little wider lobe seperation ~114 or so, but it should work fine. Doesn't look like much overlap either...
Camshaft Specification Table
Part Number 08-422-8
Engine -9999 Chevrolet
305ci-350ci
8cyl.
Grind Number CS XR270HR-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.495 0.502
Duration At 0.006 Tappet Lift 270 276
Valve Timing At 0.006
Open Close
Intake 29 61
Exhaust 72 24
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 218 224
Lobe Lift 0.33 0.335
Lobe Separation 110
Recommended Valve Springs 986-16
