cobraz240z Posted February 12, 2006 Share Posted February 12, 2006 Ok im confused! I just got a n47 maxima head for my L24, I was told I need to notch the cylender so the valves don't hit. Correct me if im wrong the N47 maxima is a 2.4 and my 1971 240z is a 2.4 same I bore I would think. I would thinks it would clear the cylenders. Im using a schieder cam part#17034 107 lobe center 460 lift 280 exhoust duration 232 intake duration. The head has the stock valves. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted February 12, 2006 Share Posted February 12, 2006 I think that setup is more commonly run on 280s to increase the compression. -Ed Quote Link to comment Share on other sites More sharing options...
1 fast z Posted February 12, 2006 Share Posted February 12, 2006 Valve springs are the SAME as the L28's. I measured them on my valve spring tester. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted February 12, 2006 Share Posted February 12, 2006 Not sure but isn't the angle of the valves different as well? Quote Link to comment Share on other sites More sharing options...
1 fast z Posted February 13, 2006 Share Posted February 13, 2006 Yea, they are not the same Cam specs, but the springs are, even though they are a 42mm intake instead of the 44, L28 series. The angles are the same, as the L28's in all aspects, Seat angle and angle realtion to the head. Quote Link to comment Share on other sites More sharing options...
cobraz240z Posted February 13, 2006 Author Share Posted February 13, 2006 Thanks guys. I have some pics of a notched cylender block im going to give it a shot hopefully I dont ruin the block. Ohh I almost forgot I have the hole cam kit springs retainers and all that good stuff. Quote Link to comment Share on other sites More sharing options...
cobraz240z Posted February 14, 2006 Author Share Posted February 14, 2006 ok I don't have to do anything to the piston do I? Quote Link to comment Share on other sites More sharing options...
madkaw Posted February 14, 2006 Share Posted February 14, 2006 You don't have to do anything to the pistons. You just don't want to notch far enough down that the top ring would reach it. When I get my block back I will try to measure somehow to give you an idea how much. Quote Link to comment Share on other sites More sharing options...
