ZZZero Posted March 2, 2006 Share Posted March 2, 2006 I currently have a 3.7 lsd r200 out of a 88turbo,and was wondering if it's possible to swap the lsd unit itself from that diffy into a 3.9 open r200.(out of an 88-89 n/a) From what I understand all I would have to do is swap the ring gear off the open diff onto the lsd unit and then put it back in.But it almost seems to simple? any input? thanks in advance Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 2, 2006 Share Posted March 2, 2006 It's really that simple. It's also been more thoroughly discussed before. Search and you might find the complete writeup, which probably has an additional 3 sentences. Quote Link to comment Share on other sites More sharing options...
ZZZero Posted March 2, 2006 Author Share Posted March 2, 2006 kool,and thanks man Quote Link to comment Share on other sites More sharing options...
Clifton Posted March 4, 2006 Share Posted March 4, 2006 You'll have to re-adjust the backlash. Get a dial indicator and base. Harbor Freight has them cheap. With 2 diffs you should be able to make the shims work. I did. Quote Link to comment Share on other sites More sharing options...
