Accelleration - Defined
Phantom
This may be a repost but it sure put things in perspective for me:
Definition of Acceleration.
* One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower
than the first 4 rows of NASCARS at the Daytona 500.
* Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro
methane per second; a fully loaded 747 consumes jet fuel at the same
rate with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to drive the
dragster's supercharger.
* With 3,000 CFM of air being rammed in by the supercharger on
overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric (stoichiometry: methodology and technology by
which quantities of reactants and products in chemical reactions are
determined) 1.7:1 air/fuel mixture for nitro methane, the flame front temperature
measures 7,050 deg F.
* Nitro methane burns yellow. The spectacular white flame seen above the
stacks at night is raw burning hydrogen, dissociated from atmospheric
water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of
an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After
halfway, the engine is dieseling from compression, plus the glow of exhaust
valves at 1,400 degrees F. The engine can only be shut down by cutting the fuel
flow.
* If spark momentarily fails early in the run, unburned nitro builds up
in the affected cylinders and then explodes with sufficient force to blow
cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate
an average of over 4G's. In order to reach 200 mph (well before
half-track), the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed
reading this sentence.
* Top Fuel engines turn approximately 540 revolutions from light to
light!
* Including the burnout, the engine must only survive 900 revolutions
under load.
* The redline is actually quite high at 9,500 rpm.
* Assuming all the equipment is paid off, the crew worked for free, and
for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second.
* The current Top Fuel dragster elapsed time record is 4.441 seconds for
the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00
mph. (533 km/h) as measured over the last 66' of the run (09/28/03 Doug
Kalitta).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered
Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and
ready to launch down a quarter mile strip as you pass. You have the
advantage of a flying start. You run the 'Vette hard up through the
gears and blast across the starting line and past the dragster at an honest
200 mph. The 'tree' goes green for both of you at that moment. The dragster
launches and starts after you. You keep your foot down hard, but you
hear an incredibly brutal whine that sears your eardrums and within 3 seconds,
the dragster catches and passes you. He beats you to the finish line, a
quarter mile away from where you just passed him. Think about it, from a
standing start, the dragster had spotted you 200 mph and not only caught, but
nearly blasted you off the road when he passed you within a mere 1,320 foot
long race course. ... and that my friend, is ACCELERATION!
I read an article on Top Fuel engines in a Motor Trend. They are developing around 7,500 HP at 9,500 RPM. Really puts my 365 at 5,500 in perspective. The technology is phenomenal and those guys are pure definitions of "brinksmanship".
That last example is kinda wrong. If the vette passed the line at 200mph and stayed there it would take 4.5 seconds to travel the 1/4mile, which is a good run for a top fuel car.
So, it would not blow past it untill it hit the light assuming that the driver of the top fuel car had a perfect light. If he had a decent light of .550, the vette would be 15ft ahead at the end.
Anyways, its still pretty cool. :flamedevi
-Dallas J
light!
That works out to $1.85 per revolution and $3.70 to complete the cycle on all 8 cylinders.
And it would blow by the Vette with a 133mph speed difference.
having been to a few nhra drags [fram autolite nationals]... i heartily recommend the experience to anyone... tv doesn't do it justice.
top fuel is just that insane.
Your hotrodding experience is not complete until you experience this in person. It is an experience you will never forget.
Having said that, the NHRA Gatornationals is March 17-19 at Gainesville Raceway. Anyone up for going on Saturday?
