I want One Of These
Dave
You don't already have one? I've got one in my back yard.......
Oh wait.. I live in an apt complex....hmmm
NIXCARS from Australia E-mailed me and said he got his off eBay
but it was a piece of junk.
Mine was last years model,and the flux compasitor was acting up.I strapped it to the back of my Grand Cherokee,and waited for a bolt of lightning.I'll post my findings yesterday.:mrgreen:
lol.
I got mine 3 months ago and all I can figure out is that it make a good paperweight, it works a little too good. Now only if I could figure out how to turn it on, it could probably restore both my Zs :mrgreen:
I thought my brother inlaw was the king in talking about something he didn't know anything about and using big words too. This guy is above him in the BS department by just a little bit.
About the time I met him, (twenty years ago or so) he said at the U of W he had a friend that had this antiradar material that when a small piece was put on the front of a car it cause the radar guns the cops use to malfuction, as in, almost blowing up.
Good my siser inlaw isn't with him now. What she's with now is worse, a recreational drug user 12 years younger than her.
Don
If I'm not mistaken the thing he said was a cardinal gram meter is two buck/boost transformers.
Turboencabulator
JH Quick
[From The Institute of Electrical Engineers, Students Quarterly Journal
25]
For a number of years now, work has has been proceeding in order to bring
prefection to the crudely conceived idea of a machine that would work to
not only supply inverse reactive current, for use in unilateral phase
detectors, but would also be capable of automatically synchronising
cardinal grammeters. Such a machine is the 'Turboencabulator'.
Basically, the only new principle involved is that instead of the power
being generated by the relaxive motion of conductors and fluxes, it is
produced by the modial interactions of magneto-reluctance and capacitive
directance.
The original machine had a base-plate of prefabulated amulite, surrounded
by a malleable logarithmic casing in such a way that the two spurving
bearings were in direct line with the pentametric fan, the latter
consisted simply of six hydrocoptic marzelvanes, so fitted to the
ambifacient lunar vaneshaft that side fumbling was effectively prevented.
The main winding was of the normal lotus-o-delta type placed in
panendermic semiboloid solts in the stator, every seventh
conductor being connected by a non-reversible termic pipe to the
differential girdlespring on the 'up' end of the grammeter.
Forty-one manestically placed grouting brushes were arrranged to feed
into the rotor slip stream a mixture of high S-value phenyhydrobenzamine
and 5 percent reminative tetraiodohexamine. Both these liquids have
specific pericosities given by p=2.4 Cn where n is the diathecial evolute
of retrograde temperature phase disposition and C is the Chomondeley's
annual grillage coefficient. Initially, n was measured with the aid of a
metapolar pilfrometer, but up to the
present date nothing has been found to equal the transcetental hopper
dadoscope.
Electrical engineers will appreciate the difficulty of nubbing together a
regurgitative purwell and a superaminative wennel-sprocket. Indeed, this
proved to be a stumbling block to further development until, in 1943, it
was found that the use of anhydrous nagling pins enabled a kyptonastic
boiling shim to be tankered.
The early attempts to construct a sufficiently robust spiral decommutator
failed largely because of lack of appreciation of the large quasi-pietic
stresses in the gremlin studs; the latter were specially designed to hold
the roffit bars to the spamshaft. When, however, it was discovered that
wending could be prevented
by the simple addition of teeth to socket, almost perfect running was
secured.
The operating point is maintained as near as possible to the HF rem peak
by constantly fromaging the bituminous spandrels. This is a distinct
advance on the standard nivelsheave in that no drammock oil is required
after the phase detractors have remissed.
Undoubtedly, the turboencabulator has now reached a very high level of
technical development. It has been successfully used for operating nofer
trunnions. In addition, whenever a barescent skor motion is required, it
may be employed in conjunction with a drawn reciprocating dingle arm to
reduce sinusoidal depleneration.
Guest James T Kirk
What button reverses the neutron flow? Where do I put the dilithium
crystals? Does it include a flux capacitor? And does it include a spare
barrilium sphere?
James T
