big-phil Posted April 2, 2006 Share Posted April 2, 2006 My car is starting to sputter again in boost, am I to rich? I just bought another set of plugs. This time NGK V power bpr6eyes-11? I think I can look for sure if need be Quote Link to comment Share on other sites More sharing options...
240hoke Posted April 2, 2006 Share Posted April 2, 2006 Definitly not too rich, tuned to a little under 12:1 my plugs are pretty black. You look like your running around stoich most of the time. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted April 2, 2006 Share Posted April 2, 2006 What are you gapping at? I have had good luck with running .032 . Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 2, 2006 Author Share Posted April 2, 2006 .43 should I go with .32? do those look to lean? or just right? Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted April 2, 2006 Share Posted April 2, 2006 looks a tad lean. drop the gap to near stock.. like .032 im running .025 for testing purposes but i run .032 also. mike Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 2, 2006 Author Share Posted April 2, 2006 You know that might be my problem. My thinking was to open the gap to make a bigger spark but mabe I went to much .43-.45ish I'll gap the new ones to .32 I put them in but have not started it yet. I'm eating now (and typing) Quote Link to comment Share on other sites More sharing options...
buZy Posted April 2, 2006 Share Posted April 2, 2006 Maybe a little lean but they look good. I really don't know the proper burn. Are you running a MSD? Something with power to the plugs when under boost? Just a thought. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted April 3, 2006 Share Posted April 3, 2006 Plugs are tricky things to read, and I'm not expert. But basically I believe you get a black coating on most things if its too rich. I run on the rich side of things (down to 11.9:1) and I have a nice black coating on most stuff. However the insulator (slightly conical bit on the middle of the plug) should be a nice brown colour if you have the right temperature plugs. When I ran 6's my plugs looked a very similar colour to yours. I don't think you are running rich, but dont' **** around with guessing, get a wideband. I was running 0.023 (0.6mm). Dave Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted April 3, 2006 Share Posted April 3, 2006 Looking further at the plugs I think they look good as far as color goes but, alot of that will depend on how the car is running off boost right before you pulled them. Also, maybe it's my screen but, do I see tiny specs of aluminum on them? Any cracks, chips, or defects of any kind? Do a search on here about NGK plugs. About a year or two ago there was some good info on here. Also Gumpyvette post some very good links about reading plugs. Heres some info: http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html Hope this helps:grin: Quote Link to comment Share on other sites More sharing options...
Alf Posted April 3, 2006 Share Posted April 3, 2006 The color looks good, but you might want to lean the idle out a little. whats your timing? whats the heat range? here's a very informative link: http://www.4secondsflat.com/Spark_plug_reading.html Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 3, 2006 Author Share Posted April 3, 2006 I was in the middle of sanding on the car also so any specs might be from lying them on the fender with bondo dust? I made another run down the road with the .32 gap on the ngk's and it felt good untill one of my I/C clamped joints blew off. Maybe thats where the sputtering is coming from? leaky I/C piping? Hell I don't know, seems like it runs great for a week or two then I have to jack with somthing. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted April 3, 2006 Share Posted April 3, 2006 Sell it and get a corolla. Dave Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 3, 2006 Author Share Posted April 3, 2006 The color looks good' date=' but you might want to lean the idle out a little. whats your timing? whats the heat range? here's a very informative link: http://www.4secondsflat.com/Spark_plug_reading.html Wow thanks for the link, your right the plugs do look good. I gess it might be my I/C piping leaking? causing the sputtering. Quote Link to comment Share on other sites More sharing options...
