mobythevan Posted April 10, 2006 Share Posted April 10, 2006 Went to a hot rodders garage today that builds rods and does machining and welding. After looking at several cool rods we go in the room where he is building one and on the bench sets a complete 1100hp twin turbo V6. He bought it from the car museum here in Colorado Springs when they shut down. It is in immaculate condition. He said it was only dyno'd then never used in the race, was just a back up engine. He had lots of other cool stuff there. He owns a GN that he drives around when he is not out in one of the rods. I wondered why he had the huge poster on the wall showing the Indy GN V6..... Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 10, 2006 Share Posted April 10, 2006 Stage II engines are awsome. My buddy that has been into Turbo Regals since day one, has a stage motor in a project car. Looks freakin' mean and all business with a 5" downpipe. Those engines can handle a lot of boost Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted April 11, 2006 Share Posted April 11, 2006 A former Indy V6 is currently being built for a Z-car here as we speak! Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 11, 2006 Share Posted April 11, 2006 I wonder who that is *snicker* Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted April 11, 2006 Share Posted April 11, 2006 might be more then one in the works... Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted April 11, 2006 Share Posted April 11, 2006 might be more then one in the works... yep.. Quote Link to comment Share on other sites More sharing options...
speeder Posted April 11, 2006 Share Posted April 11, 2006 I saw an Indy Buick Twin Turbo Stage 2 engine today, too. Quote Link to comment Share on other sites More sharing options...
savageskaterkid Posted April 11, 2006 Share Posted April 11, 2006 Heres a video of an 1100hp Grand national I found awhile back. http://videos.streetfire.net/video/3BE6651A-70A4-4D4E-8B4B-957F70032277.htm He breaks the tires loose and smokes them on the dyno-at 1076hp, So i think hes pushing a bit more then that. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 11, 2006 Share Posted April 11, 2006 Chris Chow's car is actually a twin turbo V-8 in a Buick Grand National body. I believe Chris is in the 7's now. Quote Link to comment Share on other sites More sharing options...
Some-Guy Posted April 11, 2006 Share Posted April 11, 2006 damn that was awesome I love the sound of that car Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted April 11, 2006 Share Posted April 11, 2006 Chris Chow's car is actually a twin turbo V-8 in a Buick Grand National body. I believe Chris is in the 7's now. yep, was about to say the same thing, although isn't his block made by the same folks who did the stg. 2 V6 castings? Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted April 11, 2006 Share Posted April 11, 2006 Heres a video of an 1100hp Grand national I found awhile back. http://videos.streetfire.net/video/3BE6651A-70A4-4D4E-8B4B-957F70032277.htm He breaks the tires loose and smokes them on the dyno-at 1076hp' date=' So i think hes pushing a bit more then that.[/quote'] I saw that car, I think it's a v8 not a v6. Quote Link to comment Share on other sites More sharing options...
speeder Posted April 12, 2006 Share Posted April 12, 2006 I saw an Indy Buick Twin Turbo Stage 2 engine today, too. ...In my shop. Bought from a dirt track racer, it's somewhat of a mutt: Indy block, Busch GN Crank and heads. 4.5L/274 ci, odd-fire, dry sump. It has 4-Bolt mains, Oliver I-beam 6.5" rods, Isky roller lifters, Jessel roller rockers, Titanium 2.15/1.75" valves, and a .600+ lift cam. Stone age pushrod technology executed with exotic materials and elegant machining - An 8000rpm sledge hammer! The V6 will sit totally behind the strut towers of the Z, leaving room for two big front/top mounted turbos. I don't know how much HP it will make but I will have head flow, bottom end, and turbos good for 4 digits at the stroke of the boost controller -assuming sufficient driver cajones. I have almost all the needed pieces, and the engine is in the machine shop now. Turbo conversion of the bottom end from 14:1 NA form involves new pistons and cam. The Victor Jr. 4-BBl Intake is being modified for injector bungs and a bolt - on plenum housing progressively linked twin 75mm throttle bodies. Fuel Management will be an Electromotive TEC3r driving 96lb injectors. Turbos are large frame T04/60-1s. A NASCAR-spec wide ratio 4-speed (who needs lots of gears when you have 800 or so lb/ft of torque:shock: ) , Quartermaster Magnesium bellhousing, Tilton Nextel-Cup triple disc clutch, and 2.93:1 R230V are ready. Some pictures are here; http://album.hybridz.org/showgallery.php?cat=500&ppuser=8391 Quote Link to comment Share on other sites More sharing options...
tfreer85 Posted April 12, 2006 Share Posted April 12, 2006 Speeder what is that beast going in??????? Tyson Quote Link to comment Share on other sites More sharing options...
speeder Posted April 12, 2006 Share Posted April 12, 2006 ...The V6 will sit totally behind the strut towers of the Z' date='[/quote'] I edited my post - It will replace the wimpy 424whp L6. Quote Link to comment Share on other sites More sharing options...
tfreer85 Posted April 12, 2006 Share Posted April 12, 2006 I edited my post - It will replace the wimpy L6. Thats a big replacement!!! Its gonna be crazy to say the least. Tyson Quote Link to comment Share on other sites More sharing options...
wingnutthehutt Posted April 12, 2006 Share Posted April 12, 2006 Off Topic, sorta Speeder, you have a car with that kinda body work and only a wimpy L6? I assumed there was at least a 350 under there. You don't do anything halfway though, do you? Have fun with that build. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted April 12, 2006 Share Posted April 12, 2006 Off Topic' date=' sorta Speeder, you have a car with that kinda body work and only a wimpy L6? I assumed there was at least a 350 under there. You don't do anything halfway though, do you? Have fun with that build.[/quote'] umm his L6 is anything but wimpy... L6 powa! mike Quote Link to comment Share on other sites More sharing options...
wingnutthehutt Posted April 12, 2006 Share Posted April 12, 2006 umm his L6 is anything but wimpy... L6 powa! mike Well, we're talking apples and oranges though. I mean, it's not exactly "exotic" and it doesn't live up to the bodywork. Not that I'm insinuating his car is slow. It beats the peanuts out of anything I own. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted April 12, 2006 Share Posted April 12, 2006 a L6 making that kinda power is more "exotic" and "rarer" then a V8 doing it. i know what you mean though. that Stg. 2 GN motor will be sweet though, i didnt think that was in the plans for this car but good choice! mike Quote Link to comment Share on other sites More sharing options...
