KTM-EXC Posted June 21, 2006 Share Posted June 21, 2006 Phyxius... How much boost are you running??? THanks Quote Link to comment Share on other sites More sharing options...
Phyxius Posted June 21, 2006 Share Posted June 21, 2006 about 15-16 psi on 93 octane Quote Link to comment Share on other sites More sharing options...
KTM-EXC Posted June 21, 2006 Share Posted June 21, 2006 Nice.. Have you taken your car to the track at all. Just curious because eventually I would like to have a very similiar setup. Thanks Rob Quote Link to comment Share on other sites More sharing options...
sims76 Posted June 21, 2006 Share Posted June 21, 2006 Don't mean to hijack, but I have a similar setup as Phyxius. I run 14-15 psi and pulled a 13.3 @ 108MPH at the track which is approximately 290 horses to the wheels at 2970lbs. Quote Link to comment Share on other sites More sharing options...
Phyxius Posted June 21, 2006 Share Posted June 21, 2006 I've been to the 1/8th mile. The best I pulled was a 8.73 at 84mph. My 60' really sucked, so I feel like when I get my lsd and some better tires, I should be low 8's or high 7's. My goal is 12's in the 1/4 Quote Link to comment Share on other sites More sharing options...
KTM-EXC Posted June 22, 2006 Share Posted June 22, 2006 Thanks guys for the info... What are you going to use for a LSD?? I just picked up a clutch type LSD in the junkyard from a Z31 with around 60k miles.. Only $150 I cant wait to put it in. Quote Link to comment Share on other sites More sharing options...
Phyxius Posted June 22, 2006 Share Posted June 22, 2006 I'm using the same thing except the one i got had some sheared clutches which i've heard is a common problem with those units. I've cut some new ones (see the threads in Drivetrain), and i'm putting more/stronger clutches in it to prevent any further failures. Quote Link to comment Share on other sites More sharing options...
