z ya Posted February 20, 2001 Share Posted February 20, 2001 Me and my father just finished the install of his brand new fast burn 385 sbc in his 75 280z.That motor is sooo nice.Its topped with a 750 demon double pumper and 1.75 Sandeson headers.the tranny is a TPI 700r4 with a b/m prostick.All we have left to do is the exhaust!He is going with car chemistrys inserts with 2.5 duals.Its gonna be nice! Quote Link to comment Share on other sites More sharing options...
Guest Rick Johnson Posted February 21, 2001 Share Posted February 21, 2001 Ill be real interested to hear how it runs. If it really puts out 385, your Z should scream. Hope you have a G Tek or some other way to quantify your ride. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 21, 2001 Share Posted February 21, 2001 I have the Fast Burn Heads from the 385 on my car-I went ahead and added the HOT cam and 1.6 roller rockers to make it a ZZ430 clone-The magazine tests have all verified that these motors put out the horsepower GM advertises and I can verify that this engine is a blast to drive in a Z car! I was told that this setup would be pretty radical for a street car, but on a light car like the Z the setup works great with a sensational top end above 4000 rpm. The engine is pretty docile and idles well at about 750 rpm. ------------------ Tony 1972 240Z w/ZZ430/T56/GTO body kit Quote Link to comment Share on other sites More sharing options...
danc Posted February 21, 2001 Share Posted February 21, 2001 quote: Originally posted by z ya: Me and my father just finished the install of his brand new fast burn 385 sbc in his 75 280z.That motor is sooo nice.Its topped with a 750 demon double pumper and 1.75 Sandeson headers.the tranny is a TPI 700r4 with a b/m prostick.All we have left to do is the exhaust!He is going with car chemistrys inserts with 2.5 duals.Its gonna be nice! Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted February 21, 2001 Share Posted February 21, 2001 Tony, I'm not familiar w/the ZZ430. When you say you added the "Hot Cam" are you referring to an aftermarket cam or a stock GM Hot cam. What are the spec's for that Hot Cam: Is it a hydraulic roller/flat tappet cam? 1)Lift on Int/Exh 2)Advertised Duration & Duration at .050 3)What is the Lobe Separation Angle-sometimes called Lobe Displacement Angle. Just curious? Kevin, Quote Link to comment Share on other sites More sharing options...
John Scott Posted February 21, 2001 Share Posted February 21, 2001 Its factory parts like these that make me get the V8 fever again. My knees get weak every time I read about the ZZ450 (Sallee Chevrolet) 377/383 Fast burn heads, HOT cam. JS Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted February 21, 2001 Share Posted February 21, 2001 Kevin - the specs are in the GM catalog. The ZZ430 was a 430HP 350 that was limited production and "signed" kind of thing. It had "Hot Heads", the Hot Cam, and I'm not sure what else. The 385 horse motor just has the nice heads - no cam The ZZ430 was big bucks, tough to get, and now sold out. The 385 is an AWESOME deal IMO and the addition of a cam would make it a 430 sans signature valve covers. Oh, and one of the GM places is selling a ZZ430 build-alike that has the new EFI setup on it with a reprogrammed ECU. It too is insane cash..... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 22, 2001 Share Posted February 22, 2001 Specs on the ZZ430 from the Sallee Chevrolet website: ZZ430 ENGINE SPECIFICATIONS The base foundation of the ZZ430 is the ZZ4 Short Block (See ZZ4 Spec's for more information.) Displacement: 350 cubic inches Bore x Stroke: 4.00 inch x 3.48 inch HORSEPOWER 430@5800RPM TORQUE 430@4000RPM MAX RPM 6100RPM INTAKE #12366573 VORTEC DUAL PLANE DISTRIBUTOR GM HEI Compression: 9.6:1 Block: Cast iron, four-bolt intermediate mains Cylinder Head: Cast Aluminum Fast Burn #12464298, 23 degree valve angle, Valve Diameter (Intake/Exhaust): 2.00†/ 1.55â€, Chamber Volume: 62 cc Crankshaft: 1053 Forged steel, 1 piece rear seal Connecting Rods: Forged, powdered metal, 3/8†bolts Pistons: Cast Aluminum Camshaft: H.O.T. CAM #24502586, Hydraulic Roller Tappet Lift: .525†intake, .525†exhaust Duration: 218 degree intake, 228 degree exhaust @ .050†tappet lift with a 1.6 rocker Centerline: 109 degree ATDC (After Top Dead Center) intake, 115 degree BTDC exhaust Rocker Arms: GM 1.6:1 self aligning roller rockers (Roller Tip) Timing Chain: 8 mm single roller design Oil Pan: 4-quart Oil Pressure (Normal): 40 psi @ 2000 RPM Oil Filter: AC Delco part # PF25, Premium AC Delco part # UPF25 Fuel: Premium unleaded - 92 (R+M/2) Maximum Engine Speed: 5800 RPM Spark Plugs: AC Delco part # MR43LTS Spark Plug Gap: .045 With HEI Distributor (Less with points distributor.) Spark Timing: 32 degrees maximum @ 4000 RPM Firing Order: 1-8-4-3-6-5-7-2 The key to this engine is the heads, which flow very well as cast. The valves are the severe duty ones from the Corvette LT-4 engine.The heads are about $1100, which is pretty competive with other good flowing aluminum heads. You have to use intake manifolds with the "vortec" late model design, which are available from edelbrock or GM. The heads are drilled for early 4 bolt or late center bolt valve covers. ------------------ Tony 1972 240Z w/ZZ430/T56/GTO body kit Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted February 23, 2001 Share Posted February 23, 2001 quote: Originally posted by TonyM: Specs on the ZZ430 from the Sallee Chevrolet website: ZZ430 ENGINE SPECIFICATIONS Sweet stuff is using all that great R&D GM has done use any 350 shortblock, used roller is preferred for cost current vortec bottom end takes any 'normal' (ie. oldstyle heads) bolt on edelbrock rpm's (9.4:1 overall compression and alum. heads = 87 octane and your pick of roller cams.....an Lt1 v. cheap OE cam for up to 350ish hp, ZZ4 cam for 410-420hp (hope to dyno mine this summer to back up what impala Lt1's with ZZ4's have already proven), HOT cam or any other similar one for 420+hp, I'd take a ZZ4 having heard HOT cam's and knowing how much smoother my ZZ4 sounds for my daily beast This can be a cheap motor for what you get and you can swap heads/intakes with the common bolt patterns AND bolt up a T56 if you decide with a stock/cheap clutch I'd jump at any vortec shortblock (or longblock if price is right/flip those heads and you're off to the races Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted February 23, 2001 Share Posted February 23, 2001 Just one question; Can I put a Blower & Twin Turbo's on it? (Just Kidding) I'll take two of them; one for daily driving to go into the family queen truckster & one for fun in the Z. Kevin, Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted February 23, 2001 Share Posted February 23, 2001 Hey Ross - the Performer heads are what I'm running Forged pistons, more cubes, and Eagle rods though. They went with a flat tappet cam in an LT1 block because they felt they could hit my 450HP requirement without a roller. Who knows, maybe I'll upgrade later! Had GM had the 385 out there when I was deciding there's a pretty good chance I'd have gone with it to be honest. I don't like the pistons but it had the heads I wanted on the ZZ4 bottom, I didn't care about the cam since it's so easy to change. Oh well, they've got it right now IMO. Now if GM would just put that nifty new EFI on it for less than a million bux I'd really be kicking myself in the rear! Quote Link to comment Share on other sites More sharing options...
