zcarmark Posted June 27, 2006 Share Posted June 27, 2006 Does any one know if an rb20det 5speed will hybrid with a vg30dett, or do i use rb26dett transmission. I bought an rb20det 5 spd on ebay thinking it was an rb25 tranny. I've got an rb26 engine and 5spd combo that i'm putting in my '72 240z Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted June 27, 2006 Share Posted June 27, 2006 an RB26 transmission is 4wd so you wouldnt use that. One of the guys here has an RB20 gearbox behind an RB26 motor so if you are talking a 3l version of the same motor it should mate up Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted June 27, 2006 Share Posted June 27, 2006 There was some talk a long time ago about the GTR bellhousing and Z32 trans, but I dont remember what the outcome was. Quote Link to comment Share on other sites More sharing options...
mrcheeze36 Posted June 27, 2006 Share Posted June 27, 2006 I don't think the RB20DET tranny can mate with the VG motor (without mods or a tranny adapter plate). It should mate to the RB26 block but it won't handle as much power as the RB25DET or AWD tranny. Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted June 27, 2006 Share Posted June 27, 2006 I wouldn't bother using the rb20 trans, youll blow it apart in no time. You can use a z31 turbo trans with the rb26 bellhousing. It does sit the shifter further back though. Evan Quote Link to comment Share on other sites More sharing options...
cheftrd Posted June 29, 2006 Share Posted June 29, 2006 I think what he's asking is if the RB20 bell will mount to the VG30DETT gearbox. The answer is "no". The RB25DETT and RB26DETT bells will mount to the VG30DETT box. Quote Link to comment Share on other sites More sharing options...
zcarmark Posted June 29, 2006 Author Share Posted June 29, 2006 can the tail shaft housing from a z32 tranny be swaped with a z31 tail shaft housing? I want to get rid of extended external linkage. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 29, 2006 Share Posted June 29, 2006 zcarmark said: can the tail shaft housing from a z32 tranny be swaped with a z31 tail shaft housing? I want to get rid of extended external linkage. Good question... I'd also like to see a solution to this shifter issue. Anyone know for sure? Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted June 30, 2006 Share Posted June 30, 2006 I wish I had taken pictures when I had the rear housing off of my z31 tranny. Realistically, unless there are internal differences (which I am led to belive there is not) you should be able to swap rear housings back and forth. If anyone has a pic of a z32 trans with no tailshaft housing on it, post it, I can at least tell if something blatantly will not line up. Evan Quote Link to comment Share on other sites More sharing options...
rb26zed Posted June 30, 2006 Share Posted June 30, 2006 I have done the '26 bellhousing on a vg30dett swap. The shifter is in almost the same position as the '25, it looks extended but actually comes through in almost the exact same position approx 1 to 2 inches difference at most. What engine is the z31 box from? Hope this helps, there are only a few different later model nissan boxes they just have different bellhousings which are interchangeble. The two main groups are group 1 (CA, SR, FJ, RB20) and group 2 (VG30, RB 25,26). Parts from group 1 interchange with each other but not with group 2 and vice versa. The only way I know of to get rid of the VG30 linkeage is to use a '25 box, maybe get a broken one (if possible) and use the VG or '26 internals. I don't know what group the VG20 box or earlier VG30 boxes belong to as I have never seen one before (not common over here). But there is an obvious size difference between boxes from group 1 and those from 2 so if you saw one of these you could guess which group they belong too quite easily. The other less common way is to cut the transfer case off the GTR box take out the transfer gears and weld a plate over the hole. Costs $800au over here. Quote Link to comment Share on other sites More sharing options...
zcarmark Posted July 1, 2006 Author Share Posted July 1, 2006 Thanks for all your info it has been:) big help Quote Link to comment Share on other sites More sharing options...
