zguy36 Posted June 29, 2006 Share Posted June 29, 2006 This is the Arizona Z car gt40 turbo. Two left when I bought this one.... Quote Link to comment Share on other sites More sharing options...
olie05 Posted June 29, 2006 Share Posted June 29, 2006 that thing is huge! What kind of header/manifold is that? Quote Link to comment Share on other sites More sharing options...
big-phil Posted June 29, 2006 Share Posted June 29, 2006 WOW! I want that! Quote Link to comment Share on other sites More sharing options...
zguy36 Posted June 29, 2006 Author Share Posted June 29, 2006 That is the manifold I built last winter..... sch20 stainless weld els. Look in my gallery for more pics of the manifold. Quote Link to comment Share on other sites More sharing options...
Clifton Posted June 29, 2006 Share Posted June 29, 2006 Nice. Are you running an external WG? Were did you get the stainless weld els from? Did you tig or mig it? I can't fing you gallery. Quote Link to comment Share on other sites More sharing options...
olie05 Posted June 29, 2006 Share Posted June 29, 2006 i just looked in your gallery... that manifold is sexy! if I ever went turbo I would have to have one of those on my car for sure! Quote Link to comment Share on other sites More sharing options...
Clifton Posted June 29, 2006 Share Posted June 29, 2006 i just looked in your gallery... that manifold is sexy! Were is this alleged gallery ? Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted June 29, 2006 Share Posted June 29, 2006 The inducer doesn't look all that big. Is it a GT4282R or a 4088? Quote Link to comment Share on other sites More sharing options...
spotfitz Posted June 29, 2006 Share Posted June 29, 2006 Were is this alleged gallery ? http://album.hybridz.org/showgallery.php?mcats=all&si=&what=allfields&name=zguy36&when=0&whenterm=&condition=and Quote Link to comment Share on other sites More sharing options...
Clifton Posted June 30, 2006 Share Posted June 30, 2006 [url']http://album.hybridz.org/showgallery.php?mcats=all&si=&what=allfields&name=zguy36&when=0&whenterm=&condition=and[/url] Thanks. The inducer doesn't look all that big. Is it a GT4282R or a 4088? 4082 Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted June 30, 2006 Share Posted June 30, 2006 how fast would this sucker spool on a well prepped L28ET? what kind of flange is needed for my manifold? what could this turbo do in terms of power on a L28ET, 600whp? 800whp? more? also.. for the big one. Could i easily just weld the wastegate hole shut and run my Tial 38mm Wastage??? thanks mike Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted June 30, 2006 Share Posted June 30, 2006 http://arizonazcar.com/turbos.html According to that capable of 570 hp Quote Link to comment Share on other sites More sharing options...
zguy36 Posted June 30, 2006 Author Share Posted June 30, 2006 Yes, this is a gt4082. The compressor really isn't that much bigger than the compressor on my t3/t4 hybrid with a v trim wheel. The exhaust side however is an order of magnitude bigger than the stock t3 exhaust wheel! I am going to try running the internal gate (probably futile) that came on this turbo. The weld els are from www.mcmaster.com I had the flanges on the manifold water jet cut out of 1/2" stainless, but it ended up being more like 3/8" by the time they were milled flat again. It was all tig welded together and weighs nearly what a stock cast manifold weights. Sch20 pipe is actually pretty dang thick. I am not sure when this thing is going to spool at, but I bet it will be later than sooner! To combat spool issues, I built a flap that closes off half of the housing (divided housing) until full boost comes in. This halves the AR ratio of the turbo and should help spool. The increased backpressure might be an issue though. For only $420 shipped to my door, I figured I can't go wrong with a high hp experiment Quote Link to comment Share on other sites More sharing options...
Clifton Posted June 30, 2006 Share Posted June 30, 2006 To use the internal WG on it you will need to either use a different actuator or maybe a spring to push it open. The are set a little high, I think it is over 30psi but can't remember for sure. I would check it before your first WOT run. Quote Link to comment Share on other sites More sharing options...
zguy36 Posted July 1, 2006 Author Share Posted July 1, 2006 Good point, I didn't even think that being off a diesel that it would be much more than the usual 7-8 psi setting. Thanks for the heads up! Quote Link to comment Share on other sites More sharing options...
zguy36 Posted July 1, 2006 Author Share Posted July 1, 2006 Yup, it did turn out to be a 30psi wastegate. With a quick bit of cutting and replacing of the diaphram spring, I have to back down to a managable 12psi wastegate. With a bit or rod tensioning, I even got the twin scroll flap to open just before the wastegate start to open. Should be great for building boost a bit quicker with a foolproof actuation. Quote Link to comment Share on other sites More sharing options...
